Question about NetGear WGR614 54Mbps Wireless Router (obwgr614_1)
Our router was turned off and then back on manually and now we can't get a connection to the internet - have tried reseting and everything I can think of - any suggestions to re-connect? Thanks
  • Nicholas Enyika
    Nicholas Enyika Jul 06, 2010
    The Router may have lost the IP Address setting of the ISP. If you are using a static IP Address provided to you by your ISP, access the Main Menu of the router?s configuration athttp://www.routerlogin.net, select Staus from the Maintenance tab, Check to see you still have the IP Address given too you by the ISP. However, if you obtain you IP dynamically, restart the router over again making sure the cables are properly connected. If the problem persist contact your ISP.
  • Nicholas Enyika
  • 506 Answers
The Router may have lost the IP Address setting of the ISP. If you are using a static IP Address provided to you by your ISP, access the Main Menu of the router?s configuration at http://www.routerlogin.net, select Staus from the Maintenance tab, Check to see you still have the IP Address given too you by the ISP. However, if you obtain you IP dynamically, restart the router over again making sure the cables are properly connected. If the problem persist contact your ISP.
Posted on Jul 06, 2010
N300 router has a steady orange blinking light
The blinking orange power light suggests that there is a problem with your modem. The modem should be plugged into the top ethernet port of your router. Try turning off your modem for 10 seconds and then turning it back on.
Dec 07, 2012 | Belkin Computers & Internet
I have a belkin g plus mimo that's been working fine until yesterday, when I went to get on the internet it doesn't show the router at all. No settings have been changed all the lights seem to be working I...
Enable wireless in your router.
First reset all settings to defaults.
You can RESET it with RESET button it is in back side of router press it for 10 seconds then all settings defaults.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 25, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I can access internet direct. But no internet Model dir 615
Whilst the router is turned on, try to reset the router by pressing and holding the tiny reset button at the back of our dlink router using a paperclip. Then try again.
Jan 02, 2010 | D-Link Computers & Internet
D-link won't connect to the internet
If you connect the computer directly to the modem , it shopuld work.
If your computer is online when connected only to the modem then the problem must be router settings .
you will need to check the settings manually.
Click Here for step by step solution
Nov 03, 2009 | Computers & Internet
I hit the reset button on the router and now I can't connect to my wireless network. How do I fix this?
Try turning everything off- pc, modem, router, other pcs and periferals on the network, wait 10 minutes, then start turning everything on gradually- pc, modem router, etc. Hopefully everything will reset ok.
Jul 30, 2009 | Linksys Wireless-G Broadband Router
I was using this router without problem then I moved. After reconnecting I show I am connected to the internet, but cannot browse any page. Turned everything off. Unplugged everything. Started with...
the wireless router settings must be wrong, try pressing down the reset button and hold it for alteast 30 seconds to reset the Wireless, ones that is reset try again.
Also can you tell me the brand and model of the router so incase the problem is not solved I can get you instructions.
Thanks,
Ekse
Jun 19, 2009 | NetGear WGR614 Wireless Router
Can't connect to the internet with the laptop.
if thats only the problem,try first to reset the router than to buy new one..right? i share with u this because its global crisis..jz a joke..by the way, try to reset the router within 30 seconds of pressing the reset botton backside of the router...theres a small hole..use a pin to reset that botton..and after that,you reconfigure your router..and hope everything is new..its seems to be factory reset...keep in touch...dude..
Dec 31, 2008 | D-Link DIR-625 (790069292637) Wireless...
Suddenly router stopped working!
Hi jsamanta!
First of all check if the power light is blinking or solid. if it's blinking reset your router.
When your computer is directly connected to the router try checking the IP address by clicking start>run> type cmd then ok. then type ipconfig then hit enter. IP address should be something like 192.168.1.100. not 169.254.xx.xx. if it's the latter reset your router. use a ball point pen or a paper clip. the reset button is a small hole at the back. If the IP address is like the first one i've mentioned. log-in to your router.
launch browser (internet explorer or firefox)
type http://192.168.1.1 or whatever your default gateway is. go to the status tab and check if you are getting a WAN or internet IP address. if not you will see a "release" and "renew" button. hit release then renew. if you're still not getting anything. do a power cycle. turn everything off. connect everything the way they are supposed to be connected. turn on modem first then router then computer.
If everything fails the last options is a firmware update on the router.
Hope this helps. =)
Oct 11, 2008 | Linksys Wireless-G Broadband Router
Netgear Wirless Router
You need to make sure your internet is still working. Its possible the storm caused some damage to the dsl line
Can you plug a normal broadband modem in and connect to the internet?
If you can, then try unplugging your router and plugging it back in, give it a few mins to boot up and try again (if you havn't tried this already)
If still no luck you'll have to do a master reset and set your router back up and try that, however at this point I'd guess the storm killed your router.
If you havn't got a broadband modem that plugs strait in, then ring your ISP and ask them if they've had any problems thier end.
hope this helps
Tony
Feb 27, 2008 | NetGear RP614 Router
Internet wont connect
Try leaving both modem and router off for 10 minutes. Turn them both back on and leave them alone for 15 minutes, does it work now? If not, make not of all of your custom settings (if any), try resetting the router back to factory defaults, restore any custom settings and try again. I had the same problem with a linksys and it worked after factory reset.
Sep 01, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
NetGear WGR614 54Mbps Wireless Router (obwgr614_1) Logo
65 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
