Have changed lamp on MT 1075G but now have error message ; fails to read lamp data. Contact dealer. Is there something I can do?
  • malcolm_c793 Jul 06, 2010
    Jul 06, 2010 - Not sure what you mean by "make sure the lamp genuine". Yes it is a proper manufacturer's product and once installed, the previous alarm indicator lamp that said it was beyind it's life cycle went out. So assume from that, that the lamp is ok (incidentally, if I put the old lamp back in again, the alarm indicator illuminates again), which again seems to suggest that the replacement one is ok. However, I note that the old lamp type was a MT70LP, whereas the replacement is a MT60LP. Would that matter? .
    President:
  • 1,561 Answers
The problem could be that the lamp you replace on the projector is not compatible with your projector, projector is a highly sensible, i would suggest you contact the manufacturer/ dealer for the the correct specification of the lamp, with this, the problem of error on the projector will be fixed.
Take care.
Posted on Jul 06, 2010
    do you have a number for NEC in the UK?
  • 2,069 Answers
You should check that the lamp you are putting is genuine. that may cause the system not to recognize the lamp.
I had a locked car light come on in my 2006 chevy malibu, it no longer will drive. doesnt turn off, goes in reverse but when in drive, just revs like the car is in neutral, why?
The lock an car symbol is for the anti-theft system ! By not turning off, do you mean you can't turn the key to the off position or you can turn the key to off but the car won't shut off ?
It sounds like you have a Power Mode Mismatch
The ignition switch is an input to the BCM - body control module an if something happens to the system , the BCM will keep the vehicle in the last known mode Since the operation of the vehicle systems depends on the power mode, there is a fail-safe plan in place should the power mode master (PMM) fail to send a power mode message. The fail-safe plan covers those modules, using exclusively serial data control of power mode, as well as those modules with discrete ignition signal inputs.
You could have an ignition switch problem or something wrong with the BCM .
Discrete Ignition Signals Those modules that have discrete ignition signal inputs, also remain in the state dictated by the last valid PMM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, battery positive voltage, the modules will fail-safe to the RUN power mode. If the discrete ignition input is not active, open or 0 volts, the modules will fail-safe to OFF-AWAKE. In this state, the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
This is one you need to take to the dealer because they have a factory scan tool !
Aug 03, 2015 | 2006 Chevrolet Malibu
System configuration data updated ERROR,--Need a solution I have a fairly new Gateway M-1625 laptop running windows vista 32 bit, sp1. I turned it on and beeped twice (beep, beep) and gave me an...
Got a backup?
If not, download a Linux Live CD. Boot your machine with it, save all your data to an external drive and then do a complete disk format and re-install. That will be quicker in the long run.
Not sure about that PC, but on Dell, for example, you hit CTRL-F10 (I think) at power-on and it gives you the option of reinstalling the OS from the recovery partition (wiping any unbacked-up data in the process).,,Gateway is probably similar.
The Boot/BCD issue means your 'Boot Configuration Data' is hosed.
Jun 07, 2011 | Computers & Internet
Getting an error message when starting the PSR 2100
I would do a factory reset. Search Google for: factory reset PSR 2100.
It will be holding certain buttons or keys down when powering on.
Sep 18, 2009 | Yamaha Music
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Acer aspire 3680 white screen
problably data-cable of LCD has contact problems or is broken. Consult someone with experience in opening the Display. DIY only if experienced, since you can make a $40 repair a $400 repair accidantly ... ;-)
Mar 30, 2009 | Acer Aspire 3680 Laptop
HP LaserJet 2420dn Catridge Data Error
CHANGE THE TONER!
TROUBLE BOILS DOWN TO SAME THING BUT!
IF IT IS AN HP OR A REBUILT NON-HP CARTRIDGE THE E-PROM ON THE CARTRIDGE IS BAD OR DROPPED OFF AND THE PRINTER CAN NOT READ IT.
WHAT YOU COULD DO IS TRY TO TAKE THE E-PROM FROM YOU OLD TONER (IF YOU STILL HAVE IT AROUND AND GLUE IT IN PLACE OF YOUR NEW CARTRIDGES E-PROM
Jul 31, 2008 | HP LaserJet 2420dn Printer
Error message
Replace the filter located at the bottom
Mar 24, 2008 | Canon imagePROGRAF W6400 InkJet Printer
Error Message: "Contact Your Dealer Printer Error E04-01" - What does that mean?
you can try a LBP fuser reset and LBP error log clear . this might fix the problem your having.
Mar 14, 2008 | Panasonic PanaFax UF-8000 Laser Fax
35 people viewed this question
jasbo
jasbo
