Question about Samsung Syncmaster 192N 19" LCD Monitor
Samsung 192N suspect power supply problem
Monitor switches off after 5 to 10 minutes, no lights, will not come back on.
No response to front (soft) power switch, and no response to rear (mechanical) switch either. Removing the power cord from the receptacle resets the monitor so that it comes back on, runs for another 5 minutes and dies again.
Could this be some sort of an internal heat sensor or thermal fuse that is
reset when the power is removed at the receptacle. (the rear mechanical switch does not reset the monitor, only removing the plug).
Also this is part of a multi-monitor setup and the other monitors of the same type continue to work just fine, Swapping video cables at the PC has no effect, so it is definitely a monitor problem, not the PC nor the driver.
Thanks MJS
  • 1 more comment
  • Martin J Stadler
    Martin J Stadler Apr 18, 2008
    THNX
  • Martin J Stadler
    Thanks Jemmyrash, I think so too, I can't find a free schematic for the exact model, so I guess I'll have open it up and start probing around.
  • drewboy93 Jun 18, 2008
    After the monitor has been on for about 15 - 20 min my monitor screen goes black for about 4 seconds at a time not very often to start with but the longer the monitor is on the worse it gets untill it flashes off more than its on. should i buy a new one caus they way this is going ill be sticking my foot through it. most annoying
  • 180 Answers
I'm sure it is power board failure that need repiar or replaced the defectieve parts of your LCD .
Posted on Apr 18, 2008
Samsung Monitor 192N light turns green when powered on then goes out after few seconds
this usually means the monitor is not getting a signal
  • i would check the hdmi/dvi/vga cable connections dirk_s.jpg
    both on the back of the pc and on the back of the monitor.
  • if the connections are tight, and plugged in well, maybe try and connect it to a second computer or laptop.
    • If it works the problem probably lies with your gfx card in your computer (verify this by trying another monitor on it)
  • If it doesn't work on those i would try and replace the aforementioned cable (usually pretty cheap)
  • if the problem still persists the monitor would probably need to be replaced as its defective.
Feb 28, 2011 | Samsung Syncmaster 192N 19" LCD Monitor
My monitor stays on for approx. and goes off. Taking the power off for a few minutes, it goes back on for a few minutes then goes off agoin. What is the problem?
Seen a spate of these issues of late, I'd think its caused by failing Power capacitors, either bulging or blowing or leaking. You need to get this checked by a technician or TV repairman
Dec 30, 2010 | Samsung Syncmaster 192N 19" LCD Monitor
Can't find the place to put in speakers for syncmaster 192n monitor
lemoncaketre, 192N is basic VGA only type monitor!!!! No AUDIO capabilities!! Use a set of external speakers for audio!!!
12fixlouie
Sep 14, 2010 | Samsung Syncmaster 192N 19" LCD Monitor
Turned off my power and then the monitor wouldn't power backup. Tried two power cables and neither worked, but they both worked with my other monitor. I tried the power switch on the front and back. I...
You will have to open it up and look at the main AC fuse first, then read below:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). See example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 14, 2010 | Samsung Syncmaster 192N 19" LCD Monitor
My Monitor samsung syncmaster flashes and like the light of the controls as someone to turn off and on
You need to open it up and inspect he caps in the power supply, look for bad caps with bulging tops or seals. See example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further.
Mar 11, 2010 | Samsung Syncmaster 192N 19" LCD Monitor
I have an old Samsung 192N LCD computer monitor, and I have been having problems with it. There is a large black, vertical bar about the size of my thumb on the side of the monitor. I don't have a cable to...
you need to repir the power supply and replace the screen. the power supply may have had bad capacitors on it . crowned or leaking. it will be cheaper to replace the monitor with a preowned on rather than repair it
Dec 25, 2009 | Samsung Syncmaster 192N 19" LCD Monitor
I have 2 monitors connected to 1 computer using a
satservice, What happens AFTER 15 min of FLASHING?? What did unit do or act like 3-4 weeks ago? Is the screen both BLACK and BLANK? or is screen just black and you can SEE win-desktop if you shine a bright flashlight 1 inch from screen at differnt angles? Can you use your Samsung warranty? Will monitor do same when connected to different KNOWN GOOD prebooted to desktop PC? Are you refering to the "power ON" indicator light on front BEZEL as the FLASHING thing? Need more info, but I suspect "shutdown of units "switch-mode-power-supply" due to detection of FAULT CONDITION having been detected with other circuit or with itself. Read some of my other responses in my fixya profile that deal with BLACK SCREEN repair. If this response useful, rate on fixya. 12fixlouie
Dec 19, 2009 | Samsung Computers & Internet
My samsung monitor has stopped switching on. It started just taking a while to come on but now it won't come on at all. I have had the monitor for about 2 years.
andrew_da355, you should always state what kind of monitor you have!! Do you have a LCD with CCFL back-lighting? Is it still covered by a Samsung warranty?? I suspect that it could possibly be a failure of the "switch-mode-power-supply" if it is an LCD type. A technician will need to evaluate it!! Bye for now. 12fix louie.. Read some of my other responses in my fixya profile that will also clue you in to the reason your monitor has the BLACK SCREEN of DEATH and how to fix.
Nov 11, 2009 | Computers & Internet
It recently started flickering when I turn it on. It did this for several minutes before displaying normally. Then it wouldn't display anything at all until I turned it on and off several times. Then it...
duffy325, Don't mess with it!!! Get SAMSUNG to give you a new or REFURBISHED unit t0 replace your BAD unit. Your unit is behaving like I would expect a 3-5 year old unit. It's got a power supply problem, not a front panel switch gone bad problem. FYI also visit YOUTUBE for the longer video clips of "LCD monitor disassembly" and "LCD monitor repair" to find out some common KNOWN failure mechanisims why they fail!! You will be amazed! With your unit's behavior I suspect a "flakly backlight or SMPS/INVERTER" problem. bye for now. If this was of some help, do rate this response on fixya. 12fixlouie
Nov 01, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung LCD 192N After 30 Min or so it starts flikering on & off.
The capicators on the internal power supply are overheating. You could get it repaired or find a way to cool the unit.
May 12, 2008 | Gateway FPD2275W LCD Monitor
Samsung Syncmaster 192N 19" LCD Monitor Logo
463 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
