Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
My camera when turning it on seems to get stuck when zooming out an error comes up with zoom error then it turns itself back off....
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
My camera Cybershot DSC-W150 has a problem with zoom
Sounds like your lens might be stuck. Do not force it closed or pull it out for that might further damage parts that are an integral part of its sliding mechanism. http://www.teleplancamerarepair.com/Sony_Cyber-Shot_DSC-W150 can repair this for you and they also clean your camera as part of the repair.
if there were any parts you were not able to put together after you opened it , make sure to very carefully put those back to go along with your camera.
Jul 08, 2010 | Sony Cameras
Zoom error comes up on LCD screen when trying to take picture....
I had this error and did two things to fix it and am not really sure which worked, or it may have been both:
1) Charge your batteries or replace with high power (2700) type
2)Is there a bit of dirt stuck between the zoom bit and the body?
With my S1000fd, if I press the on/off while holding the zoom bit so it cannot come out fully, I get the "zoom error" message.
Hope this helps.
Mar 28, 2009 | Fuji FinePix S1000FD Digital Camera
Zoom Error, Lens won't close
There are several causes for this to happen.
1. The lens assy is out of alignment and stuck; stalling the motor.
2. The motor itself is defect
3. If you can hear the motor working , then it will be a stripped plastic gear between motor drive and lens assy.
DIY repair not recommended (possible)
Mar 07, 2009 | Fujitsu Cameras
Olympus SP-570UZ-zoom error
Had 570UZ for 2 weeks and "ZOOM ERROR" occured. Seemed hopeless. Changed batteries several times, bought new Alkaline.
No change. Finally decided that it is probably a connector problem.
Turned Camera Off. Held Camera by the lense barrel. Held palm of other hand and thrust the back of the camera ( LCD side) into the
other hand. The idea being to jostle the camera contents without cracking the LCD. Did this a couple of times, turned camera on and it works fine. At least for this evening. At least for now it seems like a classic component connector problem somewhere inside the camera.
Oct 30, 2008 | Olympus SP-570UZ Digital Camera
Zoom error
Turn Camera off remove batteries for a few moments. Re insert batteries. Turn on will reset itself. Ensure you use correct focus settings as per instructions. If you dont use correct settings this problem will reoccur.
Oct 27, 2008 | Fuji FinePix S1000FD Digital Camera
Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
Mar 03, 2008 | Olympus SP-550 UZ Digital Camera
Zoom error
when the lens comes out, gently pull it as far as it will go, wiggle it a bit and it should right itself. just tried it with mine and it's sorted.
nice
Nov 07, 2007 | Fuji FinePix A600 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
24 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
