Question about Sanyo EM-C1800 Microwave Oven
2 difrent microwave problems
The microwave has full power to it counts down as normal but it puts no heat into food what so ever!!!
2nd micro has no power going to it changed fuse and checked wires all looks ok !!
  • 518 Answers
Is the motor with the fan on it working,thats most licklely the problem
Posted on Jul 06, 2010
2 slices of bread wrapped in paper towel microwave set on defrost set 35 seconds caught fire
Microwaves work by friction. They blast water molecules in the food so they move fast, just like rubbing your hands together makes them hot. Some types of microwave in defrost mode actually apply FULL POWER for a short period of time so to make the product warm to the touch. This heat then penetrates down to the core of the food, ensuring full defrost. In your case the heat was sufficient enough to heat the dry paper towel to set it on fire.
Bread is better defrosted on the low power setting as sliced bread is very thin. Items should only be defrosted on the defrost setting that are thick and need to be completely defrosted on the inside. Remember microwaves only penetrate the surface of food, making that hot. Thermal conduction does the rest.
You should never use paper towels in a microwave unless the instructions for doing the food say so. You wouldn't put a paper towel in a gas or electric oven, so don't put them in a microwave.
Feb 18, 2016 | In Microwave Ovens
The microwave is not heating the food.
When it did heat food before and you used the same settings now, the microwave must be defect.
But before you are sure, put a cup with water in the micro and try to heat that.
Dry food can't be heated in a microwave. There must be some moist in the food if you want to heat it in the microwave.
Mar 13, 2015 | Microwave Ovens
Our microwave, a (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few minutes later i
Not enough venting. Imagine putting your hair dryer on full and putting it that cabinet. Would your venting keep it cool? Your microwave oven uses about the same current
Dec 20, 2014 | In Microwave Ovens
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
My frigadare microwave runs normal but wont heat the food
From the description you have provided, the magnetron has shorted. This a job for a professional because there is lethal voltages present that will kill.
Mar 27, 2012 | Frigidaire Microwave Ovens
My ge xl1800 does not m,icrowave it turbns on wokrs but no hesat of the food
If everything is normal, the magnetron is the likely issue "heats food" and is the heart of the system, I suggest having it checked.
Mar 05, 2012 | GE XL1800 1100 Watts Microwave Oven
Have a GE microwave for three months bought it brand new and wife was making potatoes in it opened door to check on them and then closed door to continue cooking and it continues to count down but light...
The door switches are slightly out of alignment. If you run the microwave and shift the door up or down, the micro might begin working..
The control panel must be removed and the door switches adjusted. I would not suggest you doing this yourself, as it may affect the microwave leakage through the door gap.
Jan 02, 2011 | GE Microwave Ovens
GE microwave stopped heating food. adjusting power levels does not remedy.
If you can enter any time or power level on the micro touch pad, and the micro starts and counts down and stops, then your electronic control board (panel) is ok. The problem is in the heating energy components such as magnatron, transformer, capacitor, and diode; these components being very hi voltage and you must know what you are doing (must release the stored energy) so you do not get shocked (even if unplugged). Most often it is the diode or capacitor and it is worth repairing. Goodluck, macgivor..
Nov 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Microwave not heating food
I have exactly the same problem - strange and annoying! Did you manage to fix it?
Cheers,
Ben
Nov 15, 2008 | Sanyo Microwave Ovens
Sanyo EM-C1800 Microwave Oven Logo
142 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Oscar Netto
Oscar Netto
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
