Question about Onkyo DV-SP800 DVD Player
DvD disc won play
I put the DVD disc into the onkyo DVD player and pres play then the onkyo sais loading and after 3-5 sec ejects the DVD. The DVD is not divx it's original and i dont know what to do.
  • Anonymous Mar 23, 2014
    Won't play
  • Anonymous Mar 25, 2014
    when I put pics on dvd they won't play in dvd player
  • 518 Answers
The lazer might not be seeing the disc properly try a disc cleaner which has nylon string on it and they clean the lazer lens
Posted on Jul 06, 2010
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
My factory DVD player will except disc the ejects it
If I understand your rather cryptic post correctly...
This very well could be a Blue-Ray disk loaded into a
non-Blue-Ray capable DVD player. Your car player's capabilities MUST match the disc, otherwise, the disc won't play.
I've run into this very same problem with my home DVD players. Which both are non-Blue-Ray capable, but I was able to verify the Blue-Ray discs on my PC.
Jan 02, 2015 | Televison & Video
My dvd player keeps saying loading but will not play
Try a DVD cleaning kit, this will sometimes put more life in the player, if it fails the laser pickup assembly will need to be replaced in order to fix this problem, I would suggest a estimate before you consider.
Mar 18, 2012 | GoVideo DVD-VCR Combo
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
My onkyo DV BD-507 only play dvd disc, and dosent play blu-ray disc
Sep 25, 2010 | Onkyo DV-BD507 Blu-ray Disc Player, Black
My player when loading dvd loads for couple of secs and cuts off
Does the disc spin?
If not you have my problem spindle motor suspected faulty if the disc spins then its not being read, faulty lazer assy Try cleaning the lazer using dry brush disc philips do a good one and also clean the disc you are trying to play if it still doesnt work its a fault
Sep 02, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
DVD player will not play disc.
If you are loading a store bought DVD and that it what it say's. The transport needs to be replaced. roughly 150-200. If you are loading "burned" DVD's the format may be wrong and the unit cannot read it. Best suggestion I can give you is to first buy a "Laser Lens Cleaner" on that uses fluid. Any electronics store sells them for 15-20. Run it thru the unit a couple of times then try a clean, store bought DVD. If it plays, problem solved. With your DVD's, if you have any liquid car polish like mother's or meguiars, put a couple drops on the disc and spread around with your finger, let it set a couple then buff off with a microfiber towel. This works wonders for old scratched cd's and dvd's and helps protect new ones from getting scratched. As for the Lens cleaner, run it thru every product you have that uses discs 3 or 4 times a year, it's the best preventative maintance and only maintanance you can do on a CD player DVD or PC. Hope this helps
Jun 24, 2009 | Delphi 10.2" FLIP DOWN MNTR/DVD...
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Jul 13, 2008 | Jensen VM9510 Car DVD Player
Upside down dvd inserted
FYI - This might damage the unit, but if you really need to get that DVD out then you can try this at your own risk!
Try unpluging the unit, then plug it back in and press the power button and a split second later press the eject button. This all needs to be done quickly otherwise the unit will try to load the disc.
Or
You can try letting the unit load the DVD. When the unit says "Please eject disc. Playback feature may not be avalible on this disc," press the eject button.
Apr 01, 2008 | Emerson EWR20V4 DVD Recorder/VCR
DVD PLAYER NOT READING DISC
Well I have been repairing dvd players a while now and the main problem spots are laser ,spindle motor, laser tracking motor and the biggest culprit and un suspecting one the lens cable .....most of them range from the lens cable to the spindle motor though... the constant movement of the lens in watching a whole movie causes the cable to unknowingly and slowly break and if the spindle motor is defective ,on inserting a dvd the disc spins slowly and you may hear the lens chirping ... so you can check those....
Oct 06, 2007 | Onkyo DV-S535 DVD Player
Onkyo DV-SP800 DVD Player Logo
239 people viewed this question
Top Onkyo Televison & Video Experts
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
