Washer wont go on cycle
Wont work on any cycle. so pulled it out to check for belt wires loose ect cant see anything tried it on off chance an it worked did one wash. so put it all back tried it again and didnt work
  • Washing Mach... Expert
  • 414 Answers
If it's a machine that starts with a pump out first it may have a blocked pump. Have you tested in a different socket to rule out that?
Posted on Jul 06, 2010
FLC271W2 washer squeal during wash cycle
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
May 23, 2014 | Frigidaire Washing Machines
Ci 394 washer
during which part cycle the spin or pumping the water out just before spin cycle just before is the pump which may have been jammed pull it out and check for debris like the underwire from a bra if its the spin check belt if not belt than chances are the motor is going bad to check you would have to put a meter on it and see what amps its pulling
Mar 26, 2014 | CDA Washing Machines
Drum wont turn but the moter does
Hello Deanna - This particular issue could be caused by a variety of reasons. I would suggest trying the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then that means the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Sep 30, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washer will not start on any cycles but gentel
Thanks for choosing FixYa and welcome. It is probably your timer switch that is bad. If it works in this setting, the washer works. You may have a bad lid switch. Listen to hear if you can hear the switch click when you shut and open the lid. If so, it is probably working. It is either the timing switch or the washer is out of time. Try going through the settings a time or two. Unplug the washer and plug it back up to reset it. Since your washer does work on gentle, it is not the belt, motor, pump, ect. It is a timing issue. If you need anything else, let me know and good luck.
Jun 10, 2011 | Maytag Washing Machines
Treadmill belt stopped
Double check all your connection. Check to see if you may have pinched any wires. Also check to see if you have accidently unplugged or pulled a wire loose. If that's not the case it sounds like a lower board issue.
Jul 25, 2009 | Exercise & Fitness
Washer not finsihing spin cycle and bounces across room
Hi!
The noise could be from loose lower front weight mounting bolts or a loose bolt securing
the driven pulley. Check the belt for a weak seam and replace if necessary. Check the motor adjustment bolt for tightness.
"Ticking or Knocking" Noise In Spin: The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on upper hose hitting the topcover or a plastic injection mold standoff on the outer tub bearing housing may possibly be interfering with the driven pulley. Also, check the drive belt for a weak spot on the belt. Usually felt on the backside of the belt as a "flat" spot. Replace the belt.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
1988 Pontiac 6000
try to reset the car battery
usually pulling small fuses wont short anything out but is more likey in older cars. if that doesnt work it could be a number of things. you could have fried the ignition if there is no power to anything get the battery checked get a continutity tester and test all the wires comming off the battery to the fuse boxes to the starter alternator ect..........maybe
May 06, 2009 | 1985 Pontiac 6000
Loud spin cycle
There is a good chance that the hub nut came loose and now the split ring is destroyed, maybe along with the hub that it sits on..
To inspect these parts, the agitator must be pulled sharply and abruptly off the agitator coupler. There are no mechanical fasteners that attach the agitator to the coupler, it snaps on. A strong strap under the agitator and a quick, swift pull will remove the agitator.( Don't hit your face, it hurts)
Removing the coupler, then the basket should reveal the source of the noise.
Jun 23, 2008 | GE Washing Machines
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
