Question about Lexmark X1270 All-In-One InkJet Printer
Disconnected computer now cant get printer to work
Hi I was painting my office and had to disconnect my computer all I can see to put into the printer is the other end of the USB cable (no electric) can you tell me if there is one and what it looks like and where to find the whole for it to go in Thanks Joan
    Genius:
  • 3,587 Answers
Sure..you might find it's a smaller bore black cable, from a power supply that's on the floor.
Posted on Apr 19, 2008
Microtek Scanner thinks it's busy when it isn't
Check using a new USB cable. Unplug everything else plug into USB except for mouse and keyboard. If not work. Un-install driver and software. Download driver and latest software. Reinstall printer using driver only. Then use Paint to test it.
May 05, 2017 | Microtek MRS-1200X6U ScanMaker X6 Flatbed...
Recently disconnected all peripherals and moved computer, etc., temporarily to storage while office being carpeted. Put all back together four days later, exactly as before, but HP software says...
First double check your connecting wires correctly connected. Boot the system with all the component powered on first. Then test each component to see if they work as before? If not, restore system to a previous date that worked?
Aug 16, 2011 | HP ScanJet 5300C Flatbed Scanner
HP copy function 'device not responding or is disconnected'
Did it work at all once you reloaded the software? Is the computer recognizing it in devices and printers? If it is present, right click on the printer, go down to properties and troubleshoot.... Let me know
May 11, 2017 | HP Officejet 5610 All-In-One InkJet...
ERROR COMMUNICATING WITH DEVICE - HAVE UNSTALL AND RE-INSTALLED SOFTWARE, DOES SCAN FROM PAINT- BUT DOESN'T SCAN FROM THE PRINTER OR THE COMPUTER - I HAVE ALSO UNINSTALLED THE VIRUS PROGRAM AND STILL...
The best thing you could do is to, ( A ) disconnect the unit from computer. ( B ) un-install the software from your computer and re-boot. ( C ) Disconnect all external devices from your unit and re-start unit.
( D ) Check your device manager for any outstanding marks or flags. ( If found, remove them and re-boot. ) Check device manager again. If clear or flags,( E ) reload your software for your photosmart All-in-One printer. Note. you must have this unit disconnected, both the USB and Power connection to the Printer, until the software asked to power up and Plug in USB connections.
Hope this infomation has been of help to you.
Please rate you techs.
Oct 06, 2009 | HP Photosmart Premium C309A All-In-One...
Saying printer is disconnected
My printer said the same exact thing and when I had someone come and look at it they told me it was the port. Now I cant tell you why you and I had that happen to us but the port to the USB on the printer is the one that is not working. I just went to go buy another printer and this time a two year warranty!
Jul 17, 2009 | HP J4680 Office Jet All-In-One Printer
Unable to fax or receive faxes
Make sure the phone cord is hooked to the LINE OR FAX port.
Feb 16, 2009 | HP LaserJet 3055 All-In-One Printer
Printer Disconnected
hi pls check the conections, just do reconect and conect all cables. and check the ip also.. may be its working..
Jan 09, 2009 | Xerox DocuColor 12 Printer
Light flickering - now not even flickering
Jul 29, 2017 | Microtek ScanMaker Office Equipment &...
Scanning problems
reload your driver that came with the printer,be sure to go to properties and select shared.Although the print and scan functions use the same network cable they have diferent IP addresses and the driver software assighs the IP for scan funtion.
Mar 03, 2008 | Kyocera CS-2550 Black and White Copier
Lexmark X1270 All-In-One InkJet Printer Logo
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
