Our fitzroy cannon pilot light will not remain on once we release the control knob
  • 674 Answers
Sounds like the thermocouple that senses the pilot is bad. You should replace it.
Posted on Jul 06, 2010
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
American range fryer will not light...the knob you turn to light the pilot light will not turn.you can push it in but won't turn.please help
From the Owners' manual:
LIGHTING
1. Before attempting to light this appliance, the door if so equipped, shall be open.
2. Turn the appliance manual gas shut-off valve to the OFF position.
3. Turn the combination gas control knob to the OFF position.
4. Turn the thermostat control to the OFF position.
5. Wait 5 minutes.
6. Turn the appliance manual gas shut-off valve to the ON position.
7. Turn the combination gas control knob to the PILOT position.
8. Light the pilot with a match while depressing and holding the combination gas control knob until the pilot remains
lit upon releasing the gas control knob.
9. Turn the combination gas control knob to the ON position.
10. Turn the thermostat control knob to the desired temperature to turn burners ON.
11. Ensure that the door is closed during operation.
12. For complete shut-down, repeat steps 2, 3, and 4.
It won't turn any further until the pilot is lit and stays lit.
Jun 14, 2014 | Kitchen Appliances - Others
We have a Rinnai R82VF LPG room heater. When you press the gas button and then turn the temperature control knob to IGN, it lights. When you release the temperature control knob, it springs back to OFF and...
Part of the problem may be, that when you turn the control knob to ignition, you're not holding it in long enough for Thermocouple or Thermopile to thoroughly heat up after the pilot lights. You should hold the bottom down for 30 seconds to a minute, to allow it to heat up. Then, when you slowly release it. If the pilot remains lit, turn the knob to the desire position.
If the above doesn't solve the problem, the Thermocouple or Thermopile (aka Pilot Generator) will need to be replaced.
Hope this helped you. Cheers
Jul 08, 2011 | Heating & Cooling
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
I accidently turned the pilot off and I can't get it to turn on Williams Model# 2001622
Turn the control valve to the PILOT position and push down and hold it in. Press the Ignitor Button and continue to hold the Control knob down, once the pilot lights. Wait one minute, release the Control Knob and if the pilot remains burning, turn the Control Knob counterclockwise to the ON Position. If after the burners light and burn for a few minutes, you can turn the Control Knob back (Clockwise) to the Pilot position (if you don't want the heater to come on automatically) and the pilot should remain lit.
Hope this helped to get you back up and burning.
Mar 30, 2011 | Williams Heating & Cooling
Lennox G8Q3-90-4 will not ignite the pilot. The
While holding down the control knob for the pilot, you either have to use the pilot ignitor or match light the pilot. Then old the knob in for 60 seconds, before releasing it. If the pilot remains lit, turn the control knob to ON. If the pilot does not remain lit, the Thermocouple or Thermopile may need to be replaced.
Hope this helps you to solve the problem.
Mar 23, 2011 | Heating & Cooling
Have a Model #21V40-7 Natural Gas Rheem water heater and the pilot has apparently gone out. Can you tell me how to restart the pilot and what position the controls should be in for this model and...
The main control knob will have a "Pilot" position. Set it there, then light the pilot. You may have to press and hold the control knob to do that. There may be a striker button that will relight the pilot while you're holding the control knob or you may need to use a match or a candle lighter.
Once the pilot is on for 30 seconds or so, it will remain lit when you release pressure on the control knob.
Dec 27, 2017 | Kitchen Ranges
How do i light the pilot light on my Cannon Fitzroy gas log fire
Users manual link attched. This is for the built in put operating instructions should be the same for free standing.
Cheers, hope it helps.
http://www.sampfordixl.com.au/cannon/upload/CannonFitzroyProfilePowerflue.pdf
Jul 26, 2010 | Heating & Cooling
Light pilot light
Turn control knob to "Pilot" and press it down. While holding knob down, light pilot with a match. After pilot lights continue to hold knob down for about one minute. When you release the knob the pilot should remain on. If it goes out then the thermocouple needs to be replaced.
Jul 18, 2009 | Pool & Spa
Torpedo heater lights and runs with control kknob pressed in but shuts down when control knob is released.
Change the thermocouple. The thermocouple scenes the heat from the pilot lit and signals the main gas valve to remain in the ready condition. The main valve will not receive the signal if the thermocouple is bad and will revert to the safety shut down when the control knob is released.
Nov 20, 2008 | Dayton Heating & Cooling
Heating & Cooling Logo
364 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
