Question about Sceptre DCL 7A 17" Flat Panel LCD Monitor
SCEPTRE DCLCD 20" MONITOR
FRIENDS,
Have only had this monitor for 8 mos.
I never turn my computer off . I did and the next time I turned it on, all I got was a black screen; the blue power light goes off and on with clicking sound. I tried another monitor and it's fine, soooo monitor is the problem.
help please mhamilton53
  • ants297 Sep 29, 2008
    Got the same prob w a 20", where is the manufacturer? How do we check on product/manufacturer flaws?
  • 180 Answers
Plug it out and take for repair from technician or if you are a technician . there is problem in the main board where power comes in.
Posted on Apr 19, 2008
  • Justin Case
    Justin Case Feb 25, 2011
    Classic case of bad capacitors in the power supply board. The two offending capacitors are marked C5 and C12, a pair of electrolytic polarized ones next to the transformer. You can tell they're bad in my case because the ends are bulging, the classic sign of a popped capacitor.
    Specs: 1000uF, 16V, 105C, 5/16" diameter
    Digikey.com P/N: P12366-ND ($0.67 each)
My sceptre 30" lcd TV monitor turn on a few second then turn off only the sound is still on.I try to turn on/off many times and some time it works some time it doesn't. Could you please help what is the...
It can be the problem in the backlight inverter board or the power supply problem. You need to open it up and start looking for bad caps with bulging top first. Post back what you see inside. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 06, 2010 | Sceptre S1902D 19" LCD Monitor
At start-up, Sceptre X7 monitor flashes on, then goes black. Must turn computer on and off numerous time before monitor will stay on. How can this be fixed?
Hi Friend,
You need to check your display setting in your computer..i mean to say..you need to click on desktop then properties then display then screen saver then change the time.....
Dec 20, 2009 | Sceptre X7G-Naga 17" LCD Monitor
Sceptre 20" Monitor will not stay on
First check the monitor sleep mode for your monitor in windows control panel, check that its not going into hibernation/stanby. if thats not it. and the monitor keeps shutting down. You may have to replace it newer models have more features and could be cheaper by saving you the hassel check newegg.com or orverstock.com
Jul 08, 2009 | Sceptre X7GNAGAV 17" LCD Monitor
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Apr 07, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
Montior Repeatedly Shuts Off/Goes Black
i have the same problem .
already know what it is .
its the cfl power inverters which are build into the power supply
easy way to see is let the computer start up hold a flashlight up to the screen you should see your desktop .if so its the inverters/powersupply .
just started looking for a replacment for mine the closest i have found is around 25 bucks plus shipping wont know if it will work till monday when i can call them to match up the one i have
Jan 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Sceptre 17
It's these cheap power inverters! They blow out in 3 months.
Nov 18, 2008 | Sceptre 17" LCD Monitor
Sceptre 12ms
This sounds like a typical case of bad electrolytic capacitors. You will either have to get it repaired or replace the bad capacitors yourself to solve this. But first see if it is still under warranty.
Jul 12, 2008 | Sceptre Computers & Internet
Sceptre X9 monitor problem
hy,
usually the capacitors on the inverter board for the backgroundlight
should be replaced.
good luck
hans
Nov 17, 2007 | Sceptre computers5: X9 S-Naga II 19" SXGA...
DCLCD 19" flatscreen won't turn on correctly
Same problem here, but after using the plugging/unplugging method it eventually stopped all together. So, I took it to a local monitor repair shop (AM Stereo, Seattle). The problem is a power supply issue where the capasitors go bad. They fixed the monitor by replacing the capacitors for $70. In there experience, all monitors, regardless of brand, tend to use the same cheap capacitors which fail. He replaced them with better quality capacitors which may make this monitor better than it ever was. I'm back in business with a great monitor!
Oct 31, 2007 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Sceptre monitor will not return from idle.
The only workaround was to not use the DVI cable but to use the old VGA cable. You still get the same resolution.
I have a different ATI board, so I'm thinking it's an ATI+Sceptre on DVI input bug. Anyway, use the VGA cable, it'll work.
May 22, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre DCL 7A 17" Flat Panel LCD Monitor Logo
851 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
