Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
My automatic robokleener will move for a few seconds and then stop what could this be?
  • 640 Answers
Check your impeller. Often on these automatic pool cleaners, the impeller can become jammed and make movement impossible. Also, check your front and rear axles to make sure that you don't have any obstructions there.
Posted on Aug 02, 2010
Rotational grinding noise from front driver side (90' toyota pickup V6 automatic). grinds all the time when i get moving, sill stop for a second if i hit a bump, then start doing it again. ive alr
This sounds like the cover plate that's mounted on the side of the disk unit.It's normally fastened with two or three bolts and they do come loose at times. Could also be the actual disk pads that have worn down to metal, which will move away from the disk for a few seconds after hitting a bump.If so, make sure that your disks are not scoured as a result of metal on metal contact, whereby you would have to fit a new disk with the new pads.Check it out. Good luck.
Apr 17, 2013 | Toyota Pickup Cars & Trucks
My robokleen vac runs for a few minutes then just stops. I checked the wheels nothing is stuck in there. Any suggestions?
With these pool cleaners, there are several things that you should check. Make sure that your filter bag is not full and does not have any large debris that would hinder movement. Make sure that your impeller is not jammed or broken and check the entire drive system for objects that might have become lodged.
Aug 25, 2010 | Smartpool Dolphin Robo - Kleen Above...
Tag Heuer 2000 Automatic not moving
Sounds like your watch is in need of service. All watches need to be maintained and regular service is required. A watch is a tiny machine. So if you think about it a car needs regular maintenance to keep it running and so will any machine.
In a watch the oils dry out after about 3-5 years and they stop lubricating. Just like in a car when the oils stop lubricating the engine will stop, a watch will stop.
The reasons for this are 1) no lubrication means high friction on the moving parts. 2) the dried oils become gummy like glue and hold the gear train in place which keep the gears from moving.
The only answer is to have your watch serviced to get rid of the old lubrication, clean and replace any worn parts, then reassemble and lubricate, and finally adjust the timing.
This is something only a watchmaker should do as the parts in your watch are very small and very fragile. Improper handling can permanently damage the parts.
Hope this helps,
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
May 24, 2010 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
My watch constantly stops
check for automatic winding offcentre disc clutch mechanisum fault
Aug 24, 2009 | Seiko Watch SNXJ89K1
Seconds hand starts ticking then stops
Your band may be too loose. This is the model that moves when worn correct?
May 12, 2009 | Tag Heuer Automatic Chronograph Series...
Transmission problem
its because your saturn motor is manual and your car is automatic i have the same problem thats whaat they told me
Nov 22, 2008 | 1993 Saturn SC2
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
139 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
