Question about XFX GeForce MX4000, (64 MB) Graphic Card
Mx4000 128mb on xpsp3 problem
After installing the lates nvidia driver for this car, my monitors goes to sleep mode...no screen...cant do nothing then restart.
Any tips or advice to solve this irritating problem.
Thanks in advance,
JM
  • 93 Answers
It probably is not going into 'sleep'. just a blank screen means no video.Make sure you remove ALL the old nvidia drivers before installing new ones.You can do that in windows explorer, Nvidia > drivers.Then the machine will run on AGP drivers until you install the next driver.
If its an AGP slot card you need to use one of the older drivers as the new ones are not too hot, even with windows 7.
Device manager > display, right click > properties to get to the drivers tab.
Posted on Jul 06, 2010
  • 518 Answers
In windows power settings, you ajust the time the monitor runs and shuts down one setting is do you want the monitor to stop after 5,10 or so mins you answer never that will cure the shut down
Yesterday I was on the computer and the screen just went jagged with colors, best way to describe that. I pulled the plug since was was getting no response from ctrl alt+ delete. Or my big brother keyboard...
you might pressed a key on the monitor repress it and enable the monitor or else just remove ram from the cpu and clean it and replug it might it solve your problem
the last solution is to just format your pc
Jun 03, 2017 | HP Pavilion s3000e (GC387AV) PC Desktop
Screen resolution problems since installing latest drivers.
try to revert back to your old nvidia driver, if it works, the latest driver does not support your syncmaster, contact nvidia or samsung..
May 10, 2010 | Samsung Syncmaster 2033SW Monitor
My monitor keeps saying monitor going to sleep waht do u o
It shows that the monitor is going to the power saver mode.It is not a problem of the monitor.This happens when there are no signals received on the monitor.It turns back to the normal mode when a signal is received on it.
Dec 21, 2009 | HP w1907 LCD Monitor
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Jun 25, 2009 | Computers & Internet
HP monitor staying in sleep mode
I don't know if this qualifies as a solution or not, but to-date, the only solution I have found has been to never upgrade the video driver beyond the original "Spring 2007 Original NVIDIA Graphics Driver", installed via sp26865.exe that I got from HP support when my system was new. This file does not appear to be available now, but the support group may give it to you on special request.
Every time I "upgrade" the NVIDIA drivers, my monitor will not come out of sleep mode and only restoring to the original will work. I do not know if the upgraded driver fixes any of the advertised problems or not since I do not seem to suffer them.
Apr 09, 2009 | HP Pavilion w22 22" LCD Monitor
XP Service pack 3 will not boot with NVidia Geoforce 6600 drivers
There's a chance that your screen resolution is set higher than your monitor can handle. Try booting into safe mode and see if you can resolve the problem. You may also have to configure the BIOS to use the expansion slot that your using for the primary video, and turn the integrated (on-board) one off. (If you haven't already done so)
Jan 05, 2009 | Nvidia GeForce 6600 Graphic Card
Blank screen using Vista x64 with Nvidia Forceware Drivers 8600GT
Most like the sound card you have is not compatible with Windows Vista. You need to check the manufacturers website to see if there is any patch for Windows Vista
Oct 02, 2008 | Computers & Internet
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Monitor goes into sleep mode after a few seconds
Click on Programs --> Setting --> Control Panel
Choose the "Power Options"
in the "power schemes" Choose the Turnoff Montior, turnoff HDD, system standby
and system hibernate as "Never" in each combo box and clikc on apply.
repeat the above process for every power scheme options
Let me know if your problem is solved and rate me as FIXYA!
Feb 22, 2008 | Dell Dimension 4600 PC Desktop
XFX GeForce MX4000, (64 MB) Graphic Card Logo
336 people viewed this question
Top XFX Computers & Internet Experts
David
David
KG John Justin
KG John Justin
marley mcelhinney
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
