Question about Cell Phones
Hi.
The phone can occasionally not ring because of the following reasons:
Bad phone cable.
Defective phone system.
Defective handset.
Phone network problem (bad signal).
The first thing you can do is resetting the phone system. This is done by disconnecting the phone cable, disconnecting power adapter, removing battery from handset, then restarting the phone with the handset already placed on phone cradle.
If problem persists, test the phone using a replacement phone cable. I am referring to the RJ11 cable from the phone to the landline socket on the wall.
If all that does not work, the phone is probably defective. In that case test the phone on a different network to find out if the problem is the phone or the network.
Posted on Jul 06, 2010
Mar 18, 2016 | GE Lands Phones
Apr 08, 2012 | GE Telephone pr521w
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
Feb 01, 2010 | HP Officejet 6500 Wireless All-in-One...
Nov 17, 2009 | Uniden Cordless Phone
Mar 25, 2008 | GE 21028GE3 Cordless Phone
Jan 05, 2007 | GE 21018GE3 Cordless Phone
Aug 11, 2006 | Telemania 027367 Spiderman Animated Phone
Apr 22, 2018 | Samsung Cell Phones
Apr 22, 2018 | Cell Phones
22 people viewed this question
