Question about Whirlpool Washing Machines
F33 code - Whirlpool Washing Machines
    President:
  • 1,294 Answers
1 Unplug washer /disconnect power
2 Check wire harness connections to the pump & Central Control Unit (CCU)
3 Plug in washer or reconnect power
4 Verify CCU operation with Diagnostic Test or any cycle
This occurs when the connection between pump & CCU is lost.
Posted on Mar 12, 2009
Everytime i try to run a load of wash i get a F33 error - what can i do?
Please clarify the Model and Make of your Washer.
The F33 error for Whirlpool: The "F33" error code means that the washer has encountered a system error with the pump drive. The parts should be working fine; it is just the connection that caused the problem.
Check connectors on central control board.
Mar 09, 2011 | Washing Machines
What is f33 code
F33 deals with the drain pump....
http://www.searshomeservices.com/shs/question?questionId=225063
Here is a link to a PDF document with ALL your error codes and remedies.
good luck and don't forget to vote
Oct 12, 2010 | Kenmore HE2 Plus Front Load Washer
What does F33 mean- its the code on my front loader washing machine
"F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch. The flow meter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Thank you !!
Jul 15, 2010 | Kenmore HE2 Plus Front Load Washer
Washer codes F01/F33, have cleaned the pump and
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore He2plus washer that gives me an error of F33
Thank you !!
Jun 19, 2010 | Kenmore HE2 Plus Front Load Washer
Error code f33 on an he4t
Oct 11, 2009 | Kenmore Washing Machines
F33 error code. drum begins to rotate and then
Jun 06, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore elite he3t model 4596640 year 2005 f33 code
May 05, 2009 | Kenmore Elite 45986 Front Load Washer
Error code f33
Jan 25, 2009 | Kenmore HE2 Plus Front Load Washer
F33 error code
F33 System leak If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
1. Check for crack or holes in the washer tub and pressure switch hose.
2. Replace components if necessary.
Jun 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
243 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
