Question about Toshiba Satellite M305-S4826 Laptop
Okay I have a 14-month old Toshiba Satelite M305-S4910. A few day ago the screen began to flicker if it was tilted to certain angles. That got more extreme until now I can't get the display to work properly. In the right lighting I can make out certain things (bright pictures or a little text) on the screen but otherwise it just seems blank. What exactly could the problem be?
I have a M305-S4831, the screen started flickering a couple months ago and it seemed that the problem was related to the position of the open screen.
Somewhere I read that the cable connector has very tiny contacts and one may need a new monitor cable. Well, this is what I did with fantastic results:
1. I removed the 4 screen frame screws which are under the 4 plugs.
2. Carefully remove the frame, there are the normal plastic snap into place clips around the frame on all four sides. Use a very thin screwdriver or knife blade to get the first of the clips to release then just keep going around until all clips are free. CAUTION: the wireless antenna cable goes along the left side of the screen from bottom to just around the top left corner.
3. Notice the cloth covered cable on the left side that ends with a white plastic plug set. Mine was "secured" by a small piece of yellowish scotch tape.
4. Gently unplug the connection, I used my fingernails ever so slowly to get it apart, then reconnect together. This 'scrapes' the contacts clean a bit.
5. Get out your favorite hot glue glue gun and heat it up. Then I just hotglued the cable to the cover inside surface for about a half inch distance backward from the white plug. I secured not only the cable but also a bit on the connector itself as well.
6. Now when I open and close the lid, the cable end is fully secured but the cable is still free to twist as required.
7. Restart the computer and check your screen by carefully moving the cover...the screen should not flicker any more.
8. Reinstall the monitor frame and 4 screws and plugs.
9. Enjoy a normal monitor.
10. I did not want to buy anything, and I figured I had nothing to loose by trying this. So far it has worked for me.
Posted on Jul 24, 2010
  • roro622 Aug 31, 2010
    I too have a 16 month old Toshiba doing the same green screen stuff. If I do this, will it stop the heated monitor at the lower part of the screen?
    I currently added a desk fan to blow on it in addtiion to my cooling pad.
    UGH, I don't know if I will buy another Toshiba....
  • 93 Answers
You may of course have a dying screen. I hope not! However it may be that the driver that runs it is corrupted. many video drivers get accidentally corrupted.You really need to post the windows OS for this.
If you have restore discs you can run one of them to reinstall the video driver. Put the disc in and let the computer boot off it.
Depending what sort of disc you have (an original OS disc or a 'setup' one provided by Toshiba,) you can reinstall the driver if you can see the screen..
Control panel > device manager (that's what you need to reach in any version of windows) Display adaptor. Right click that and select properties. select the driver tab. select uninstall and then restart the puter. It should find the driver and reinstall it automatically.
Posted on Jul 06, 2010
I have a screen freezing on my laptop Toshiba satellite m305-s4910 and the pointer not moving.thanks
Either it's getting to hot or you have gotten infected, try cleaning the vent with canned air... if you can run a virus scan, Older Toshibas are notorious for getting hot...
Oct 23, 2013 | Toshiba Satellite Computers & Internet
Laptop screen flickering when battery charging
The power supply adapter may not be delivering enough power when you run it and trying to charge the battery at the same time. The only way to find out is sub another power supply.
Jun 19, 2012 | Toshiba (M305-S4910) PC Notebook
Toshiba Satellite m305-s4910
remove the battery pack and power source. make sure nothing is plugged into the laptop. hold down on the power button for 30 seconds. then reinstall battery, plug the the adapter into a known live power source (the real reason for your problem) and power it up!
Jan 16, 2012 | Toshiba Satellite M305-S4826 Laptop
Toshiba satellite m305-s4910 flickering toolbar
My M305-S4910 was doing the same thing. After some research, I replaced the video cable. The flickering was not as bad, but still there. I just replaced the inverter, and the pink line beneath the toolbar is now gone and so is the flickering. :-)
Sep 13, 2011 | Toshiba Satellite M305-S4826 Laptop
Laptop display is hard to see and the brightness function keys do not increase or decrease screen brightness.
There is a possibility that your screen backlight has malfunctioned. go get it replaced. that should solve your problem.
Feb 03, 2011 | Toshiba Satellite M305-S4910, M305-S4915...
During BIOS update the computer ( toshiba m305-s4910) froze. I disconnected the computer by removing the the power cord and th battery. Later, I put the battery back and connected the power plug. What I...
the bios is the operating system in the chip attached to the mother board
It is the primary system that gets the computer working (turns on all of the right electronic switches so to speak to boot up and power on)
It never needs up dating and the confusion is caused by the updating references to the operating systems ( win xp, 7 8 vista etc) which are not the bios
Sep 01, 2017 | Toshiba Satellite M305-S4910, M305-S4915...
Toshiba L300 screen flickers and backlight
Maybe is the backlight power cable cut. Try with the laptop in power on mode oppening VERY SLOWLY the screen to see if at a certain potition it works fine. Open it all the way up sometimes to check it. If thre is a potition that it works, it's the cable as I mentioned.
Stelios
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
LCD flickering at the bottom of screen
This appears to be a faulty CCFL lamp which supplies the back-light.
Because it is less than 6 months old, I suggest you get it fixed under warranty.
If you try to fix it yourself you will void your warranty.
Feb 12, 2010 | Toshiba Satellite M305-S4826 Laptop
Light flashes as straight line at the bottom of my laptop screen
Does it display the BIOS screen or anything when you first power it up? If you've only had it for six months, the laptop should still be under warranty. I would contact the manufacturer on this issue.
Jan 12, 2010 | Computers & Internet
My new Satellite M305-S4910 is experiencing a monitor flickering. What can I do to stop it flickering?
Remove the power strip above the keyboard and the keyboard and remove the bezel on the LCD. This will give you a clear view of the wiring leading from the screen to the motherboard. Look for a loose connection or rubbed or frayed wiring. Also, a lot of video problems are from the cable getting loose that runs from the back of the screen. This is a flat cable the fits in a socket on the back of the screen.
Here is the lcd removal duide for your laptop....
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M305/remove-screen-inverter-video-cable-1.htm
Sep 22, 2009 | Toshiba Satellite M305-S4826 Laptop
Toshiba Satellite M305-S4826 Laptop Logo
657 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
