Question about OKI B4350 Laser Printer
IT LOOKS LIKE MY PRINTER NEEDS SOME KIND OF CLEANING BECAUSE IS NOT PRINTING CORRECTLY,HOW CAN I DO THIS?
  • 518 Answers
The lazer units can be ezchanged for new/recharged ones
Posted on Jul 06, 2010
Yellow shadow around letters and photo when card is printed
Hello Joseph,
Could you attach a photo showing the printer's internal test card?
To print the built-in test card, press and release the small test button on the rear of the printer. This may give some clues as to the cause of the problem.
Check that the printer has been thoroughly cleaned with the special cleaning cards (Magicard Part Number: M9005-761).
A video showing the cleaning sequence can be seen here;
http://magicardonline.net/
You will need to enter your printer's serial number in the QuickSearch box. Then choose the Videos tab on the left.
Check the card thickness adjuster setting is correct.
Finally, ensure there is no dye film stuck to the print roller.
I hope the above information is helpful.
Kind Regards,
MC.
Apr 15, 2014 | Magicard Rio Card Printer
When I try printing a 5X7 card the writing is not aligned on the page correctly.
This may be a problem with your printer. If it has any kind of paper guides I suggest you slide them into the correct posistion. Or it may be a format problem with your printer and it needs to clean itself.
May 04, 2011 | Computers & Internet
Getting streaking when printing with Canon Pixma MP610. Read somewhere Printer Head needs cleaning, If so, how do you remove It? pkoaktown
Look on your PC. There is a maintenance menu for this printer. Follow instructions to do the head cleaning. If that is not enough you can remove your printer print head and try to clean it with dry cloth or with some kind of alcohol.
good luck
pifonski
Feb 19, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Head cleaning doesn't work
Generically it is difficult to suggest a solution that suits you best.
My best guess is that the "Print Head" may be clogged with dry ink and that needs to be cleared to allow further ink through. This can be achieved using "Print Head Cleaner Solution" available from Ink Resellers and the like.
Use "Google" with your printer type and model number with the words "Clean Print Head" you should find some answers on Forums on the correct method to locate and clean your Print Head. If not, the previously mentioned Ink Resellers may offer a "Cleaning Service" but unfortunately Printers in most cases have become "Throw Away" when trouble occur.
As a side, my daughter used to call this "Secret Messages" when it occurred to our early printers.
Kind regards
Apr 12, 2010 | Office Equipment & Supplies
Printer is not printing colors correctly. Brown looks red. Is there a way to clear ink heads or ink area. case shows ink spillage, need to clean up area maybe will help with color printing.
You press the ink button and choose cleaning option and test print to see if colors are correct, clean again if colors are wrong. The spillage won't hurt print quality when it's around the cartridge area. If you are using generic inks they sometimes are not the correct color.
Feb 08, 2010 | Brother MFC-440CN InkJet Printer
Out of paper message
there is a paper guide that supports paper on the tray, if you look closely you can even see the paper sizes that corresponds with your printer either (lettter size or 8 1/2 x 11) if this is not set correctly then you can get skewed on your prints, if i understand you correctly, or kindly elaborate some more
Jul 11, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Print head cleaning utility.
I cannot remember if the tools menu is embedded in the properties of the printer driver. The previous poster I believe is correct. If it does not appear, go to start, run, all programs, then select the HP or Hewlett Packard section and look for an HP Toolbox or similar utility that will have options for cleaning/aligning/testing the printer..
Feb 24, 2008 | HP DeskJet 5652 InkJet Printer
Royal Cash Register 130 cx Does Not Print Correctly
Cleaning and alignment is needed to solve these problems. As you can notice, the printer has various gears and small parts on it. Although the alignment for this kind of printer model is too complicated that only an authorized technician is capable of doing it. If you can look for an authorized service center for your cash register on your area then try to contact them. They either render home service or you will have to bring your unit to them.
Jan 23, 2008 | Office Equipment & Supplies
Brother mfc-5460cn terrible print quality
does it copy an image correctly? if it does than the problem is with the driver or your computer. in the setting menu try turning off the "true to Life feature as this can sometimes cause this kind of problem
Sep 01, 2007 | Brother MFC-5840CN All-In-One InkJet...
OKI B4350 Laser Printer Logo
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
