Question about Hotpoint Ultima WF860 Front Load Washer
F 03 showing on machine
Hi, My machine keeps taking in water and flashing F03. Can you tell me what the problem is please?
Regards
Kathie Richards
Yes F-03 indicates a faulty thermistor (it's inside the heating element at the back). Before calling an engineer, just open the bottom rear panel and check that the connector has not come loose (OR IN MY CASE FALLEN OFF COMPLETELY). This can happen if there is a spin cycle that runs out of balance big time. (two thin wires on a square unit about 5mm in size fitted to the middle of the heating element).
Posted on Jul 17, 2010
    President:
  • 1,382 Answers
"F03" fault code indicates that the wash thermistor is open/short circuited .Thermistor is inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to the temperature. This error also indicates a poor connection to the main PCB. It is high time to call a service person to replace the thermostat in your unit.
Thank you !!
Posted on Jul 06, 2010
Hotpoint ultima WF860 is taking water but showing error code F03 i opend the back cover and found the cable hanging down from right hand side of heating element and it was burnt out and the terminal at the heating element so i replaced the burnd wire and also i changed the heating element but (did not changed the thermistor ) and its still showing the same error code, do i need to change the thermistor is well? can any body help please
Posted on Aug 24, 2010
F03 error message on Hotpoint WT741
Error F03 indicates that the wash thermistor is open or short circuit.
Check the thermistor, heater and connections.
Hope this jelps.
Jan 09, 2010 | Washing Machines
Hotpoint wt746 flashing f 03
Hi
Thanks for using FixYa. By error F03 in Hotpoint washer we mean that the thermistor is open. This will not let the water to heat or in rear cases will boil the water to extreme temperatures. You’ll need to replace the thermistor to resolve this issue. The thermistor is located in the motor control unit. Also check the element if its open circuit, you’ll get a reading of 1.5-1.8K ohms on the multimeter, if not then element is bad. The element is also located in the motor control unit. You can check them by removing lower rear panel.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Washing Machines
Keeps going to f-03
  • F03 - Wash thermistor open/short circuit
If this error persists it's usually best to call fro service unless you are familiar with this kind of work.
Apr 18, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Ultima WMD940 F-03 showing on display
The error code F03 indicates a problem with the pump out of the washer or a failure of the pressure switch that controls the water fill. This is a problem that you should have a technician diagnose and repair.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Hotpoint Washing Machines
Indesit 1200 series wont work.
F03 indicates that the wash thermistor is open or short circuit, the thermistor is part of the heater element. you need to test the heater and thermistor, and possibly replace.
Indesit recommend that you call an engineer, but it can be done by some one who is competent enough.
Unplug before you do anything to it.
Plz leave feedback.
Thanks
Dec 10, 2008 | Indesit W 123 Front Load Washer
Hot point aquarius wf740
Hi.
I think you need to call engineer to sort the problem
Please leave feedback.
Dec 02, 2008 | Hotpoint Aquarius WD640 Front Load...
Error code F-03 Indesit wixe127
Hi.
The code F03 means the wash thermistor is open circuit.
Unfortunately, you will have to call an engineer.
Cheers.
Nov 18, 2008 | Washing Machines
Wt741
not sure if this is repairable but wonderedif anyone else has had the same problem,my wf860 keeps flashing f-03.
Oct 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT KEEPS FLASING F-03
The error code F03 indicates that the wash thermistor is open or short circuit.
Check heater element and thermistor,if ok, then you need to call an engineer.
Sep 22, 2008 | Hotpoint Aquarius WD63 Front Load...
Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Feb 10, 2008 | Indesit W 123 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
871 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
