Troubleshooting hi,, recently i have joined in one company as network admin so i want some troubleshooting things, plz hel me out Regards vinay
  • 4 more comments
  • vinay787 Apr 19, 2008
    I am not able to ping other router of our branch location
    but i can make telnet.... i think ICMP problem, r they
    blocked ICMP....
    what are the precaution i have to take
    when router get crash
  • vinay787 Apr 21, 2008
    how to block and unblock icmp
    and i am unable to telnet directly to the router i have to go
    via switch, i mean first i have to telnet and from switch to router
    i think some one block even telnet also... so how to unblock it
    please guide me
  • vinay787 Apr 22, 2008
    We have MPL's connection in all our branches to connect.
    if there is down in MPL's connection, router will trigger isdn line
    automatically. But in some of our branch the router wont trigger
    we have to trigger manually. It is a bit difficult to me because
    in every 1/2 hour i have to ping and check whether the all branches are working or not... Please help me
  • vinay787 Apr 23, 2008
  • Mark Kessler May 11, 2010
    what kind of problems are you experiencing?
Telnet and ICMP can be disabled on specific interfaces by use of Access list commands. You will have to check the router configuration to see if any access list statements exist on the interfaces. They are usually applied to the serial interfaces, which is probably the reason why you could not telnet or ping directly to the router. If there are no access list commands then that means telnet was not configured in the first place.
To disable an access list command, you need to type the entire command with the word 'no' in front of it.
It is not recommended that you disable these features, as it will open your network up to possible attacks. If a hacker were able to telnet to your router and guess the password to login, you could be in for a whole host of problems that you are probably not ready for. Be sure that if you do enable telnet, that you use a very strong password for telnet access.
Posted on Apr 21, 2008
  • 221 Answers
Telnet is an application layer protocol. If you can telnet to the other router, then you do not have any network issues. However, the fact that you can telnet but not ping suggests that icmp messages have been blocked in the configuration of one or both routers. This is a security feature, because attacks can be launched via icmp messages.
Posted on Apr 19, 2008
  • Mark Kessler Apr 19, 2008
    First thing you need to do is back up the ios which is located in flash memory. You should back up the ios for each router you manage, and name them distinctly so that you know which ios is for which router. You should back up your ios to an external source, such as a server, desktop, or external storage device. You should do this immediately, before a crash should occur.
    If you are using cisco routers, log into the router, then type
    'copy flash tftp'
    you will then be instructed to provide the ip address of the tftp server, along with other information related to the file.
    Another thing, if both routers are the same make and model, one ios version can most likely be used for both.
Htc troubleshooting
Similar thing happened to mine recently and I found the following fix:
Press and hold the "volume down" button then press and hold the "power" button.
Hope this works for you as well.
Regards Alan.
Sep 03, 2014 | HTC One SV
Windows unable to find a certificate to log on to the network
Sometimes domains are not available until they are removed and re-added to a machine. You can try logging in locally as an admin, remove it from the domain, verify you are on the network, reboot, and add it back to the domain. A local machine login circumvents the need for a cert to login, but does not give access to domain resources. This will allow you to work on the machine and test the NIC you are troubleshooting.
Dec 02, 2013 | NetGear WG111 802.11g/b Wireless Adapter
Uh065sx lock on busy mode. won't recieve any signal. how do unlock it.
You obviously haven't got the user manual with the troubleshooting section, so here is the best solution:
Join a yahoo group specific to your brand and model i.e,. Uniden UH065sx, there you will be given the right advice, freely downloadable manual, plus other goodies.
I Hope this helps.
Feb 16, 2013 | Uniden Radio Communications
Dear sir, my acer laptop very slow oprate. I 2 times formet after same proble. plz sugest me.
if that is the case, you might as well replace the power supply or the motherboard. That is literally the reason why your PC slows down despite the fact you reformat it.
Jul 18, 2011 | Computers & Internet
My acer 4315aspire laptop problem is .1st i on a laptop and my laptop screen is completely white.then i restart my laptop so screen is good during a work screen is again plz help me my problem...
your problem is there are 4 possibilities.
1 - LCD problem
2 - problem with LCD cable
3 - inverter problems.
4. display card problem
to identify the problem, you have to do troubleshooting.
1 - The first thing you should connect the external display
(monitor) on buieldin display
If display appear in a normal on an external display, this means that there is no problem on display card.
2 - If you have identified the problem not the display card, you have to do further troubleshooting process by opening the cover lcd screen on your laptop, and perform troubleshooting of hardware one by one in the list.
1 - LCD screen
2 - Inverter
3 - LCD Cable
after you do all of these processes will know your results.
Normally the problem is the lcd screen.
Apr 29, 2011 | Computers & Internet
I have a turbosteam 6060 sunbeam iron. It will not steam, just beeps and cycles off
If I was you I would either go to the Sunbeam site and in the search box enter the model name and number and get a download a manual for fixing the iron or troubleshooting problems. If that don't work Send the Iron back to the company for a new one.
Feb 11, 2011 | Sunbeam 3017 Iron with Auto Shutoff
What if the default username and password do not work on a G704WG router
The default username and password for GT704WG router is
username: admin
password: password
If your not able to login, then please click on the link to reset the password
Thanks & Regards,
Jan 06, 2011 | Actiontec GT704WG Wireless Router...
Having Trouble Connecting iPod Touch to Airtunes Network
try setting it up on your iPod Manuel instead of selecting the router from your iPods list hit the other box the enter your routers name encryption type and your password and see if that works hope this helps
Dec 22, 2008 | Apple iPod touch
VPN connection timed out
please tell me that who is your ISP at home?
Oct 25, 2008 | Trendware 54Mbps 802.11g Wireless AP
Problem Accessing Network
Well Have You Studied The OSI Model Yet ?
Physical Connection is the first Layer , So I would say the physical connection.
when troubleshooting Network Problems don't complicate things from the start work from the bottom up
So Physical Connection is Step 1
Aug 20, 2008 | Computers & Internet
Computers & Internet Logo
849 people viewed this question
David Payne
David Payne
