Question about Dimplex DGWH4031 Heater
Looking for ainstlation diagram for installing a storage heater
  • 518 Answers
Try the dimplex web site ,that may help
Posted on Jul 06, 2010
Need to change heater coil need a diagram to do so
  1. Drain the coolant. Refer to Draining and Filling Cooling System .
  2. Remove the instrument panel storage compartment.
  3. Disconnect the electrical connectors, as necessary.
  4. Remove the center floor air distribution duct.
  5. Remove the hinge pillar trim panels.
  6. Remove the blower motor cover.
  7. Remove the blower motor.
  8. Remove the steering column.
  9. Roll back the instrument panel. Refer to IP Carrier Replacement in Instrument Panel, Gauges and Console.
  10. Remove the coolant recovery reservoir.
  11. Remove the heater hoses.
  12. While holding the heater case to the cowl, remove the screw on the interior side of the cowl, near the evaporator pipe, if equipped.
    1. On the engine side of the cowl, remove the 4 screws that hold the heater case to the cowl.
    2. On the engine side of the cowl, remove the 2 nuts that hold the heater case to the cowl.
    3. Remove the heater case. Ask an assistant for help, if necessary.
    4. Remove the 7 screws that hold the heater cover to the heater case.
    5. Remove the heater cover.
    6. Remove the heater core from the retainer.
    7. Installing
      1. Install the heater core into the retainer.
      2. Install the 7 screws that hold the heater cover to the heater case. Replace the seals.
      3. Install the heater cover. Verify that the heater cover is properly sealed.
      4. Install the heater case. If necessary, ask an assistant for help.
      5. On the engine side of the cowl, install the nuts that hold the heater case to the cowl.
      6. On the engine side of the cowl, install the 4 screws that hold the heater case to the cowl.
        1. On the interior side of the cowl, install the screw.
        NOTE : Refer to Fastener Notice in Cautions and Notices.
        1. Tighten the following fasteners:
        Tighten
        • Tighten the screws on the engine side of the cowl to 1.9 N.m (17 lb in) .
        • Tighten the two nuts to 2.8 N.m (25 lb in) .
        • Tighten the screw on the interior side of the cowl to 11 N.m (97 lb in) .
        1. Install the heater hoses.
        2. Install the coolant recovery reservoir.
        3. Roll forward the instrument panel. Refer to IP Carrier Replacement in Instrument Panel, Gauges and Console.
        4. Install the steering column.
        5. Install the blower motor.
        6. Install the blower motor cover.
        7. Install the hinge pillar trim panels.
        8. Install the center floor air distribution duct.
        9. Connect the electrical connectors, as necessary.
        10. Install the instrument panel storage compartment.
        11. Add the engine coolant. Refer to Draining and Filling Cooling System
        12. Inspect the system for leaks.
Dec 15, 2010 | 1999 Chevrolet Silverado 1500
My dimplex xms718n storage heaters are not heating up properly - the bottom half is still cold in the mornings what could be causing this?
I have recently had xms718n storage heaters installed and about once a week none of them seem to come on at all. Do you know why?
Dec 09, 2010 | Dimplex Heating & Cooling
Insallation instuction for 29 gallon storage tank
the pressure valve usually has it's own hole,....a pressure valve (relief valve) has a probe that needs to be immersed IN the tank,...get that manual from the supplier (their responsibility), this part not being placed properly can be dangerous! so please don't take any chances,......
Oct 30, 2009 | Stiebel Eltron TEMPRA 12 Tankless Water...
I have a creda storage heater 79153, i turned it on on sunday night monday morning it was still cold , i changed the fuse at the wall still nothing, the only part that works is the convector heater at the...
Check the fuse board it should be marked up (but often is not especially if POLISH electricians concerned) it should be a 32 amp fuse.
The heater has a thermal fuse installed internally £12 replacement, these tend to be the only things that go wrong with storage heaters! get a qualified electrician who you trust to have a look otherwise who-ever looks at it will say its F****d and will take you to the cleaners
Oct 21, 2009 | Heating & Cooling
1996 suburban heater core, it is leaking?
PLEASE REMEMBER TO RATE ME THANK YOU RejakWilson
HEATER CORE
Remove or Disconnect
  1. Engine coolant.
  2. Instrument panel storage compartment.
  3. Electrical connectors, as necessary.
  4. Center floor air distribution duct.
  5. Hinge pillar trim panels.
  6. Blower motor cover.
  7. Blower motor.
  8. Steering column.
  9. Roll instrument panel back.
  10. Coolant recovery reservoir.
  11. Heater hoses.Screw on interior side of cowl, near the evaporator pipe (if equipped) while holding heater case to the cowl
  12. Four screws on the engine side of the cowl holding the heater case to the cowl.
    1. Two nuts on the engine side of the cowl holding the heater case to the cowl.
    2. Heater case.
      • It may be necessary to have an assistant when removing heater case.
    1. Heater cover.
      • Remove seven screws that hold cover to the heater case.
    1. Heater core from retainer
Install or Connect
  1. Heater core into retainer.
    • Install seven screws that hold heater cover to heater case.
  1. Heater cover.
    • Make sure heater cover is properly sealed.
  1. Heater case.
    • May be necessary to have an assistant when installing heater case.
  1. Nuts.
  2. Screws.
Tighten
  • Screws on engine side of the cowl to 1.9 N.m (17 lb in) .
  • uts to 2.8 N.m (25 lb in) .
  • Screw on interior side of the cowl to 11 N.m (97 lb in) .
  1. Heater hoses.
  2. Coolant recovery reservoir.
  3. Roll instrument panel forward.
  4. Steering column.
  5. Blower motor.
  7. Hinge pillar trim panels.
  8. Center floor air distribution duct.
  9. Electrical connectors, as necessary.
  10. Instrument panel storage compartment.
  11. Engine coolant.
    • Check the system for leaks.
Mar 28, 2009 | 1996 GMC Suburban
Changing a heater core
here is a step by step diagram to replace your heater core
Front
  1. Disconnect the negative battery cable.
  2. Drain the cooling system.
  3. Remove the instrument panel glove compartment.
  4. Tag and unplug all electrical leads as necessary.
  5. Remove the center air distribution duct from the floor.
  6. If necessary, remove the ECM and mounting tray.
  7. Remove the hinge pillar trim panels.
  8. Remove the blower motor cover and then remove the motor.
  9. Remove the steering wheel and tilt back the instrument panel slightly.
  10. Remove the coolant overflow tank. Disengage the heater hoses at the core connections.
  11. Unfasten the attaching screws and nut and then remove the heater case.
  12. Remove the seven screws and lift off the heater case cover.
  13. Remove the fasteners and brackets that hold the heater core to the case and lift the core from the case.
To install:
  1. Install the heater core in the case.
  2. Install the heater case bottom plate. Make sure there is a good seal.
  3. Install the heater case into the truck. Tighten the 4 lower screws to 17 inch lbs. (2 Nm); the upper screw to 97 inch lbs. (11 Nm); and the nuts to 25 inch lbs. (2.8 Nm).
  4. Connect the heater hoses at the core tubes.
  5. Install the coolant overflow tank.
  6. Install the instrument panel and the steering wheel.
  7. Install the blower motor and cover.
  8. Install the trim panels and if removed, the ECM. Install the air distribution duct and reconnect all electrical leads.
  9. Install the glove compartment. Fill the cooling system and connect the battery cable.
  2. Drain the engine cooling system into a clean container for reuse.
  3. Disconnect the heater hoses from the heater core.
  4. Remove the instrument panel storage compartment.
  5. Disconnect the electrical connectors, as necessary, that may be in the way.
  6. Remove the center floor air distribution duct.
  7. Remove the hinge pillar trim kick panels.
  8. Remove the blower motor cover screws and the cover.
  9. Remove the blower motor screws and the blower motor.
  10. Remove the steering wheel and the steering column (standard & tilt).
  11. Remove the instrument panel fasteners and pull the instrument panel back far enough to gain access to the heater assembly.
  12. While holding the heater assembly against the firewall, remove the screw located on the interior side near the evaporator pipe, if equipped.
  13. In the engine compartment, remove the 4 heater assembly-to-chassis screws and the 2 heater assembly-to-chassis nuts.
    NOTE Removal of the heater assembly may require the help of an assistant.
  14. Remove the 7 heater cover-to-heater assembly screws and the cover.
  15. Remove the heater core from the heater assembly.
    93113g80.gif View of the front heater assembly—Chevy/GMC C/K-Series, Blazer, Jimmy, Sierra, Suburban, Tahoe, Yukon
    Click to Enlarge
    93113g81.gif Location of the front heater assembly-to-chassis fasteners—Chevy/GMC C/K-Series, Blazer, Jimmy, Sierra, Suburban, Tahoe, Yukon
    Click to Enlarge
To install:
  1. Install the heater core to the heater assembly.
  2. Install the heater cover and the 7 heater cover-to-heater assembly screws.
    NOTE Installation of the heater assembly may require the help of an assistant.
  3. In the engine compartment, install the 4 heater assembly-to-chassis screws and the 2 heater assembly-to-chassis nuts. Torque the screws to 17 inch lbs. (1.9 Nm) and the nuts to 25 inch lbs. (2.8 Nm).
  4. While holding the heater assembly against the firewall, install the screw located on the interior side near the evaporator pipe, if equipped. Torque the screw to 97 inch lbs. (11 Nm).
  5. Install the instrument panel and the instrument panel fasteners.
  6. Install the steering column (standard & tilt) and the steering wheel.
  7. Install the blower motor and the blower motor screws.
  8. Install the blower motor the cover and the cover screws.
  9. Install the hinge pillar trim kick panels.
  10. Install the center floor air distribution duct.
  11. Connect the electrical connectors that were disconnected.
  12. Install the instrument panel storage compartment.
  13. Disconnect the heater hoses to the heater core.
  14. Refill the engine cooling system.
  15. Connect the negative battery cable.
  16. Run the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
Dec 31, 2008 | 1994 Chevrolet C1500
ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Feb 14, 2008 | Sub-Zero 690 Side by Side Refrigerator
Dimplex DGWH4031 Heater Logo
88 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
