Question about HP Officejet 4355 All-In-One InkJet Printer
There was cartridge error Today replaced with HP Original but printer not responding showing connection error
  • 518 Answers
Sounds like the cartridge is not sitting propperly in the housing so the contacts are not making,try running the aliament program that should help
Posted on Jul 06, 2010
  • 3,600 Answers
Remove the cartridge and clean and reinstall then try it if it still does not work then thne run the cleaning cartridge applacation for it. if that does not work. go to this web site anddownload the trouble shooting tool, it has the latest software for fixing your problem and you will need to select your operating software to download the correct one, aslo if your running wierless you may have to change settings and if your running cables you may have to turn the machine off and remove and plug printer and computer back in and try again, here is the web site to try to get help, if you don't see the problem listed if you type in your name and e-mail address they will give you free live chat support to help you figure out your problem. Please go here.
http://h10025.www1.hp.com/ewfrf/wc/searchResults?tmp_product=HP+Officejet+4355+All-in-One+Printer&product=1138373&tmp_qt=connection+error&lc=en&dlc=en&cc=us
I have hp cm 8050 printer showing error code D1.073B
follow this steps and fix it. God bless you
Instructions
    • 1
      Ensure that the HP printer cables are properly connected. If in doubt, turn off the printer, unplug it and disconnect all of the printer cables. Plug it back in and reconnect the cables. Turn the printer back on again to see if the error has cleared.
    • 2
      Check the HP printer cartridges and print heads to ensure that they're installed properly. Also see if the printer cartridges are empty. If the ink cartridges have sufficient ink, reinstall the cartridges and the print heads. If an ink cartridges is empty, replace it with a new one.
    • Sponsored Links
    • 3
      Make sure that the HP printer's software is properly installed. If the device does not respond when you try to print or the printer software won't initialize, uninstall and reinstall the HP printer software.
    • 4
      See if your computer's firewall is preventing the HP printer from functioning properly. Open your firewall preferences and add the printer software executable file (*.exe) as an exception or disable the firewall temporarily to see if this fixes the error.
    • 5
      Check the print settings in the HP printer software if the pages don't print properly. Make sure that the margins are set to at least the minimum margins that your HP printer supports. Also ensure that you've selected the correct printer settings for the paper size and type of document you're trying to print. To access these printer settings more easily, open the HP Solution Center.
    • 6
      Clean and align the printer cartridges. Open the software for your HP printer or the HP Solution Center to access these maintenance features.
    • 7
      Double-click on the HP printer icon in the system tray on the bottom right of the screen, if it appears. Look under "Status" in the printing queue to read the error messages. Right-click on the entries and select "Cancel," if necessary.
    • 8
      Navigate to the HP website to search on your specific printer model if these steps fail to fix the printer error. Click on "Support and Troubleshooting." Click "Solve a Problem" to find solutions for the HP printer's specific error. Also check the "Software and Downloads" area for software and driver updates.
Read more: http://www.ehow.com/how_4999655_fix-hp-printer-errors.html#ixzz2Z7d9rxWS
Jul 15, 2013 | Office Equipment & Supplies
I have an HP 3800 color laser printer. I installed a refurbished toner cartridge today and received a "49.2F05 Service Error" on its display after it completed self calibration. I am assuming it...
A critical firmware error has occurred.
1. Turn the printer off and then on.
2. Try printing a job from a different program. If the job prints, try printing a different file from the original program. If the message appears only with a certain program or print job, contact the software vendor for assistance.
3. If the message persists with different programs and print jobs, disconnect all of the printer cables that connect to the network or the computer.
4. Turn the printer off.
5. Remove all memory DIMMs or thirdparty DIMMs from the printer. (Do not remove the firmware DIMM in the lower slot J1).
6. Remove the printer EIO card.
7. Turn the printer on.
8. If the error does not persist, install each DIMM and EIO device one at a time. Turn the printer off and then on again after installing each device.
9. Replace DIMMs and EIO devices as necessary.
10. Reconnect all of the printer cables.
11. If the error persists, replace the firmware DIMM.
12. Replace the formatter and calibrate the printer.
Jul 16, 2011 | Office Equipment & Supplies
Hello, just today my printer (HP Officejet 6310 All-In-One InkJet Printer) showed an error saying , "Cartridge Error: Cartridge in the left must be replaced. I put ink on both , just in case that was...
You need to decide upon a suitable replacement. HP recommends using their ink cartridges, but you can also choose to use a cartridge from a different brand. If you have a higher volume of prints, you may even consider refilling old cartridges to cut down on costs.
Remove the old cartridge by removing the main cover. The cartridge carriers will automatically move to the center. Press the top of the carriers to open the plastic lids covering the cartridges. Gently press down on the old cartridge and slide it out.
Install your new HP printer ink cartridge. Remove the blue protective strip from the contacts and place the cartridge in the carriers. Press down gently until the cartridge sits in its position. Replace the carrier lid and main printer cover. Restart the printer and take some test prints.
Nov 17, 2010 | HP Officejet 6310 All-In-One InkJet...
HP colorlaserjet 2840 shows no ink
always use original hp cartridges and now u shud get ur printer checked by technician or if u want our technician help contact us at http://tinyurl.com/mtgjzz
Jun 22, 2009 | HP Color LaserJet 2550n printer + HP Color...
Error "remove and check color cartridge" after cartridge was refilled.
try cleaning the contacts opd the color cartridge
with a wet towel
if the problem is not solve return the cartridge in the shop you get it and ask them to replace it
Apr 13, 2009 | HP Photosmart 2610 All-In-One InkJet...
Ink Refill for HP Photosmart c7280 not working
Hi Lisa,
If it responds ok with the old cartridge then the problem is with the cartridges' chip not the printer. Probably the manufactor has a problem with certain cartridge chip (contact them!). I would suggest to use the original at the problematic spot if it works without a problem.
- Gilberto
Dec 15, 2008 | HP Photosmart C7280 Laser Printer
HP officejet 6110 all in one
Probably one of two causes:
1)Cartidge is Faulty/Out of Date/Not original.
2)Printer is Faulty.
Most HP cartridges have a specific life, no matter if you use it or not. You should check the cartridge life - its printed on the cartridge itself. If its in date and broken you can get a free replacement from HP. Try a new cartridge first.
If you are still getting an error message after changing the cartridge and your printer is no longer in warranty, its normally cheaper to throw it away than get it fixed. If its in warranty, call HP. They normally replace very quickly.
Sep 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Check Printer Cartrige
my printer is
HP PSC 1410 ALL IN ONE PRINTER
ERROR MESSAGE
1. CHECK PRINT CARTRIDGES
I AM REMOVE THE OLD CARTRIDGES
THEN NEW ADDED 21,22 CARTRIDGES
THEN NEXT ERROR MESSAGE
HOW TO SOLVE THE PROBLEMS
Jul 09, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP Officejet 4355 All-In-One InkJet Printer Logo
201 people viewed this question
Seeker5211
Seeker5211
