Question about Brother MFC 7420 All-In-One Laser Printer
2 sheets of paper get jammed and need removing after every Fax/photocopy. one gets stuck just as it has come out in the out try (just need to pull the end out) the other gets stuck under the cartridge.Is there a way of stopping it happening every time?
  • 518 Answers
Why is it taking in 2 papers everytine too much paper in tray? thats the usual trouble
Posted on Jul 06, 2010
I get message to pull out jammed paper but I cannot find end of the paper to pull out
Try blowing the printer out with a can of compressed air. Tiny bits of paper will often get stuck in the "eye" of the optical reader that tells the printer that it has a jam. Compressed air can blow this debris loose.
Another thing to double-check is the paper tray. Remove the paper tray and inspect the place where the paper gets pulled into the printer. Sometimes you will find a sheet of paper stuck there that isn't readily apparent anywhere else.
Aug 03, 2015 | Epson PictureMate 500 InkJet Photo Printer
How to reset error 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, <OPEN COVER> and <SEE FIG. 1> <!!CHECK!! 5100> are displayed on the LCD.
Note
You do not need to unplug the fax when clearing document jams.
* When <OPEN COVER> and <SEE FIG. 1> are displayed alternatively
1. Press [Stop].
Important
Do not pull out the jammed paper manually at this point.
2. Hold down [Start/Copy] for a few seconds.
* The document will be fed out automatically.
* If the document is not fed out, gently pull the document out of the fax.
* When <!!CHECK!! 5100> is displayed
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, <CLEAR PAPER JAM> is displayed on the LCD.
1. Gently pull any jammed paper out of the fax as shown, then press [Stop].
* Pull it gently in either direction.
* If you cannot pull the paper out, continue with the steps below.
2. Open the Printer Cover.
3. Gently remove the jammed paper inside the fax.
4. Press [Stop].
The fax returns to standby mode.
Sep 24, 2013 | Canon FAX-JX200
Paper jam 2 but no paper is stuck
Most printers/faxes need more than one or two sheets of paper in the hopper in order for printing to commence. If it's not that, take out all paper. Turn off the printer/fax. Wait five minutes and turn printer/fax back on. With some printers/faxes, that almost acts like a re-boot. Good luck!
Mar 28, 2012 | Samsung SF-5100 Plain Paper Laser Fax
Paper not going through and when it does it jams
Clean the entire printer of old paper, and bits and paper. You will be surprised how often a little piece of paper is stuck somewhere. Buy a bright LED torch, keep by printer ,so can check carefully.
Try a thinner paper, 70gsm. Thicker paper jams more often.
Buy fresh pack of paper. Paper gets wet. Old paper jams.
If older printer then the rollers might be dirty and sticky. Can use a cotton bud to wash with alcohol. Otherwise put your paper in a closed container and keep it dry. If damp/humid , then the paper gets sticky.
I am a finance whistleblower and have used some 10 printers and 1 10,000$ photocopier, all worn out. Sometimes just got to go buy a printer.
Buy the most cheapest printer. When it dies, go buy another. That way never loose money on big scan/print/fax dog printers. Use a local fax company and photocopy company - let them wear out their printers.
God bless John
May 04, 2011 | Office Equipment & Supplies
Paper jammed when loading paper, don't know how to clear jam
Welcome to FixYa.
To clear the paper Jam, follow the steps below.
1. Remove all loose paper from the paper In tray.
2. Do not pull paper jam from under the front cover.
3. If there is more than one sheet stuck in the printer, remove the paper sheet at a time.
4. Make sure no scraps of paper are stuck in the printer.
5. If there is open the door at the back of the printer.
6. Pull the jammed paper out of the printer.
7. Check again to make sure no scraps of paper are stuck in the printer.
8. Close the back door.
9. Restart your computer.
Hope this information will help.
Thank you for using FixYa.
Mar 24, 2011 | HP Photosmart 2610xi All-In-One InkJet...
How can i remove the paper inside the printer
For the paper jam issue turn around the printer and open the back door to pull the paper.
and for the power issue unplug power cord from wall and from the printer side too,plug everything back and ready to work.
Aug 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I have an Intellifax 2820 and there is an error message of paper jam inside... I have cleaned all paper out of machine... please help me
A jam sensor may be stuck by a paper scrap. Try manually pushing a sheet of paper through the machine IN THE DIRECTION IT IS NORMALLY FED. This may force out any stuck scraps. The jam sensors are usually located where the paper feeds and where it exits the machine. Also, make sure ALL ACCESS PANELS YOU OPENED TO CLEAR JAMS ARE CLOSED PROPERLY. Otherwise, the jam code will not clear.
Nov 25, 2008 | Brother IntelliFax-2820 Laser Fax
How do I remove the covers on a Xerox XE60 Photocopier?
Try forcing a sheet of paper through the machine by hand. Feed the paper only in the direction it normally goes. This may free up the sensor. Thin cardstock may be used instead of paper.
Sep 28, 2008 | Office Equipment & Supplies
Scanning / faxing problem
you will need to replace the adf assembly or the portion of adf roller which was dameged.
typically one should open th ecover and take out the jam inth direction of papermovement only
happy faxing
omnipresent
Oct 17, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
140 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
