Question about JVC GR-DVM5 Mini DV Digital Camcorder
I have a jvc gr-dvm5. what happens is e01 appears on the screen and i can't put any tapes into the machine.The power is working fine. cheers Tom
    Guru:
  • 551 Answers
Try this:
remove the battery, then insert it. then try inserting your tape in.
Posted on Jul 06, 2010
What cable do I need to connectmy GR-DVM5 to i-MAC
no cable is useful, use video grabber device to connect with i-MAC .
Oct 18, 2015 | JVC GR-DVM5 Mini DV Digital Camcorder
The viewfinder on my gr-dvm5 isnt working it is just blank
Possible fault in the display unit , either the LCD drive has failed or a pico fuse has blown inside.
Remove battery and insert after sometime and see if there is any signs of picture coming in and then getting blank. If so the display processing is faulty.
It will be better to get the camcorder checked by the JVC service for an estimation to decide.
Aug 27, 2010 | JVC GR-DVM5 Mini DV Digital Camcorder
JVC Camcorder Error code E 01
Your camera can not load mechanism completely(E01). Could have problem with mechanism or the mode motor itself fails. By the way, serial number is not necessary. Good Luck
Mar 20, 2010 | JVC Cybercam GR-DX95 Mini DV Digital...
I have a jvc gr-sxm26u camcorder and it has two problems... the tape door will not open when the eject button is pushed to the left. 2nd problem. the screen indicates that there is a problem labeled as "...
E01 Mechanism has not fully loaded up to the stop position
E-01, E-02, E-05, or E-06 is an Emergency Error Code. In the event of a malfunction the unit will shut down and display a code which is to inform a technician which area of the camcorder to examine in order to ascertain the nature of the problem. Try the following steps:
1) Remove power source for 1 minute. 2) Reattach power source. 3) Try operating the camera.
The indication E-03 or E-04 is an Emergency Error Code. In the event of a malfunction the unit will shut down and display a code. This is to inform an independent JVC authorized service center which area of the camcorder to examine in order to ascertain the nature of the problem.
The E-03 or E-04 code relates to one of the tape spindles not turning. This could be the result of too much slack on the video tape. If E-03 or E- 04 is displayed it may be possible to correct the problem by removing the tape slack. In order to do this follow these steps:
3) Press "EJECT" (DO NOT PRESS POWER)
4) Repeat above steps until tape ejects.
5) Tighten and insert a new tape."
A common E01 problem with the JVC is caused by electrically conductive residues on the very end of the connector strip which connects the small front circuit panel to the main circuit panel (this residue can only be seen under a microscope). Symptoms are, the mechanism remains closed or the cassette holder will not latch down and remains permanently raised. Basically the micro cannot read the mechanism position data. The connector strip needs to be taken out & carefully cleaned with alcohol.
If all else fails then its a trip to JVC service and a biil of between $`100 and $250 depending on what the problem is. My last E01 was a motor change and cost $180 but the cam has been fine ever since but next cam will be a Canon..
Oct 14, 2009 | JVC GR-SXM260U Camcorder
JVC GR-D30U Digital Video Camera error E04
there was a hole under the tape deck.. u can try to force;y open it right there
Sep 01, 2008 | Cameras
Can't install a tape
Unplug it from power and disconnect the battery. Hit the reset button then wait about 15 minutes. Afterwards, you can plug it back in or connect the battery and it should be business as usual. If it shows the error code 3 times in a row, then take it to a shop.
Jan 22, 2008 | JVC GR-DVM5 Mini DV Digital Camcorder
Conectar JVC GR-DVM5 al ordenador con el sistema operativo Vista
necesito drivers para bajar videos desde mi camara jvc gr-dvm5 al computador que tiene windows vista home.alguien me puede ayudar con alguna informacion o sitio donde los puedo encontrar??
Dec 23, 2007 | JVC GR-DVM5 Mini DV Digital Camcorder
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
E01-E06 Unit in safeguard mode
I had this same problem, and indeed it was from leaving a tape in the camcorder while in storage. All I did was remove the tape and put a new one it. Solved my problem! Thank you!
Dec 03, 2007 | Video Cameras
LCD screen goes plain grey
i think it's the case of damaged flexible cable to the lcd screen from the camera. a replacement will do the job
Jun 27, 2006 | JVC GR-DVM5 Mini DV Digital Camcorder
JVC GR-DVM5 Mini DV Digital Camcorder Logo
158 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
