Question about DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale
What to do
I have 2 DigiWeigh pocket scale. both of them are not working.. As soon as i turn the scales on it says F--H and I have know idea what that is supposed to mean... please help me to render this problem if possible. Thank you
    Guru:
  • 551 Answers
Have you tried removing the battery then insert it again? if not please do try. thanks.
Posted on Jul 06, 2010
How can you fix error on screen can it be reset
It often just needs recalibrating. Try turning the scale on while holding the mode/tare button with nothing on the scale. Then press the tare button again. It should show a calibration weight which you should put onto the scale. Then it automatically calibrates.
Nov 30, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My digiweigh scale reads HHH. What does this mean and how do i fix it?
It worked on mine,
I pushed Mode, Power, Tare at the same time.
It came up in Cal mode.
I added penny's till it was 995 or so then added small pieces paper to it till it was 100 then up popped passed. I turned it off then it works fine now.
Thank You!!!!!!!
Oct 19, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
How to fix an easy weigh digital scale
the 24c02 is a memory chip inside. Unless your a tech - you can't repair.
Jun 07, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
DigiWeigh pocket scale showing..UnSE code..what is UnSE code?
Remove the battery - this happens when the scale tries to use a dead battery instead of the wall power supply.
May 02, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My scales i turn it on and the number keep going different and there is nothin on it
  1. First, try recalibrating the scale with nothing on it.
  2. If there is a reset button on the device, press it.
  3. Try replacing the battery.
  4. If it still acts up, it's probably time to get a new scale.
Feb 18, 2011 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My scale is frozen displaying f--h how do I fix this? I tried holding mode and tare and turning it onon and that doesn't work any other suggestions?
Reset it!
Turn off the scale. Press and hold the MODE button and turn the scale on. Release the MODE button you will see the scale's internal count.
Press and hold the TARE button then press (don't hold) the MODE button you will see the full capacity is changing. Keep pressing the MODE while holding the TARE button until you see 100.00 on the screen. The reset is completed. You may need to recalibrate the scale after the reset.
Nov 09, 2010 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
When i turn on my digiweigh dw 100ax scales F--H appears on the screen how do i fix that and calibrate the scales when done
I thought the scale was just completely broken, I was able to fix by doing the following.
1. turn unit off
2. hold down the on/off/tare AND the MODE button.
3. The unit will come up with a bunch of numbers on the screen. Release the buttons
4. Press MODE once, you will see "100" flash on the screen. if you don't press the button a second time.
5. place 100g of tare weights on the scale.
6. Press MODE button again. After this my scale said PASSED and shut off.
7. remove tare weights and turn device on. It should now register properly.
In my case. the scale was misregistering the 50g weights as 75. I shut it off. I pulled up ever so slightly on the scale plate on the hinge side of the plate are repeated steps 1-7.
I have no idea why they don't have a 3 part calibration on these.
It is working like a charm now!
Sep 04, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
F--H APPEARS WHEN TURNED ON AND FREEZES
that dosent work in the case of an f--h display at least in my case i think the f--h stands for f**king hopeless
Jun 17, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale Logo
1,284 people viewed this question
Top DigiWeigh Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a DigiWeigh Measuring Tool and Sensor Expert? Answer questions, earn points and help others
