Question about Jenn-Air JES8850BA Electric Kitchen Range
Model JES8850BAS. front left element doesnt work.
Model JES8850BAS. front left element doesnt work. Control panel doesnt work no matter what you press.
    Guru:
  • 551 Answers
There is a problem on the panel. please call a technician to repair that problem.
Posted on Jul 06, 2010
Not working
I hope that I am wrong but I think that you will need this part.
Range electronic o...PART NUMBER: 74011719
Substitution: 8507P226-60
Manuals, parts list and diagrams are available here.
http://www.searspartsdirect.com/partsdirect/part-model/Jes8850bas?page=1
Searching Model For Search Your Way Jes8850bas 2
Aug 30, 2014 | Jenn-Air Jes8850bas Stainless Steel...
I have a Fisher&Paykal DD6031 drawer dishwasher. Stopped running mid cycle. Lights flashing on drawer front green,red,yellow,red green,red,yellow . I don't know what that code means. On the inside Heavy...
follow this steps and fix it. GOD BLESS YOU
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Could this be a User Interface,Board 316239500 part problem? or a Electronic Control Board part problem?
Normally, the E.O.C. (electronic oven control) only controls power the ehe bake/broil side for the oven. Doesn't control power to the element. If you have already replaced the infinite switch to that eye, the element itself could be faulty. There is a sensor inside the element that is supposed to communicate with the infinite switch to determine the proper cycling temp for what you selected.
Jan 31, 2013 | Frigidaire GLEF396 Electric Kitchen Range
I have a Kemore series 90 dryer model number 110.60922990 with a non removeable back and I am trying to change the heating element...I dont see any way to get at the element..the back doesnt come off and...
The bottom panel will come off after releasing the tabs between the lower panel and the front panel. Once the lower panel is removed, you will have access to the heating element. The link below will take you to a breakdown picture of your dryer.
Kelly
Mar 22, 2011 | Dryers
My washer is over flowing? It doesnt matter which level I put it on either. My water level needs to be adjusted.
The tube to the level control is probably plugged. Take the cover off of the front. On the left had side of the tub is a white tube. Pull the tube loose from the tub. Blow on the tube and you should hear a "clicking" up top. that is the level control switch. If you cannot blow keep working and get it cleared. If tube is clear then the level control switch is probably bad. I am no expert but unfortunately experienced on working on this model.
Nov 27, 2010 | GE Profile Prodigy WPSE4200A
I have a mdl CZF725 rival deep fryer and the lid will not stay down.
The problem is that the heating element and front control panel is not sitting in correctly. Remove the heating element/front control panel. Grab the heating element and gently pull it away from the control panel. Use care as you can break the elements off of the control panel. Reinsert and attempt to close the lid. If it does not close, then repeat this process being careful to not over bend the elements. The lid uses two plastic extensions to latch to the control panel and if the control panel is extended away from the fryer front, the lid will not latch. Also the fryer will not work as there are sensors in the control panel to sense if it is close enough to the fryer.
Jul 18, 2009 | Rival Kitchen Appliances - Others
Bottom oven element not working
Only 2 things left. A bad wire or bad control board.
Remove the rear panel. Set the range to bake,check power at the element terminals with a voltmeter. Ifyou do not have 220 volts at the element replace the ERC.(clock).
May 23, 2009 | GE Ovens
How to remove stove top to replace element on JES8850BAS
i would imagine you would not have to remove te front control paenl eitherfew screw around sidesand back
heres a complete service manual for the model number, loos asif its adowndraft cartridge model not a glasstop , removing main top pg 26
http://www.servicematters.com/maytag_library/docs/16026926.pdf
Nov 23, 2008 | Jenn-Air JES9860 Electric Kitchen Range
I have an Amana Elec. Dryer. Model # DLE 330 RAW that all of sudden quit heating. This dryer is about five years old. It has 7 cycles and 3 temp controls. Could this be a bad heat control switch or a...
It could be a circuit breaker, fuse, or electrical problem. Just because the motor runs doesnt mean it will heat.
You should check for power first.
Then unplug the dryer remove the lower front panel, two screws.
Mark and label any wire you remove so you know where they go!
in the back on the left is the heating element, check for burnt wires, take the element out and check for a broken wire on the back side also check all the thermostats, and electrical components to make sure they are good.
ask more questions if needed
Jul 15, 2008 | Amana Dryers
Jenn-Air JES8850BA Electric Kitchen Range Logo
234 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
