Question about Canon PIXMA iP4600 Color InkJet Photo Printer
Hi Just Bought a new aP4600 everything is fine except that it will only print in Cyan and yellow can you help with this please?
  • 518 Answers
One of the cartridge jets is blocked or that chamber is empty run cartridge program for cleaning and may fix the trouble
Posted on Jul 06, 2010
Aficio SP C411DN does not print cyan
Well, since you've tried everything, my recommendation is to try to clean the contacts with dry cloth in the left or right side inside the printer where the cartridges place in. see the result
Feb 01, 2014 | Ricoh Aficio SP C411DN Laser Printer
HP Officejet 6310 will not print cyan
The Cyan print head nozzle maybe blocked.
If deep cleaning does not fix it then you need a new print head.
The cost of a new print head is expensive and it maybe better to get a new printer.
Oct 15, 2012 | HP Officejet 6310 All-In-One InkJet...
The colors do not print correctly.everything is blue/green/yellow. the ink cartridges are new. black prints fine. the troubleshooting optin only lets me select to remove lines, it wont let me adjust the...
The magenta cartridge isn't working correctly. This is why you're only getting the other colors (blue is cyan, green is cyan and yellow, and then yellow).
Try removing and reseating the magenta cartridge. If that doesn't work, use a new magenta cartridge (the cartridge itself may have been defective).
I wasn't able to view a manual for this machine, as it's been discontinued and Lexmark no longer offers the PDF on it. If you have a "clean print heads" option, use it. It may require more than one try. If you don't have that option, then all possibilities have been covered.
Hope that's helpful.
Jan 01, 2011 | Lexmark X1150 All-In-One InkJet Printer
I have an HP Phototsmart C4280 that is printing everything in pink. Any idea why?
This is the cartridge color problem, if you've refilled the cartridge, there must be proportion problem (magenta/yellow/cyan), or if you print dark colors like green or blue (which uses cyan and yellow mostly) and never use the red or other color (magenta and black), cyan and yellow might have finished up. If you can refill it proportionately, go ahead, but i would suggest you to purchase new cartridges and install.
Good luck. Thanks for using FixYa.
Jun 04, 2010 | HP PhotoSmart C4280 Laser Printer
My magicolor 2350 has cyan print problem
replace the cyan image unit might go a bad one
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 04, 2009 | Minolta magicolor 2350 Laser Printer
All new toner but prints everything blue
I kinda don't doubt it at all. It could be a bad lot of toner, or another problem with a mechanism within it...regardless, you're cartridge is defective -return it.
Jun 15, 2009 | Brother HL 1440 Laser Printer
Printing yellow for black
Hi Jan,
Can you confirm that you are using a CIS or non-HP cartridges with this printer?
It sounds a lot like the printhead has reached a clogging point where sediment has built up in the black portion and loosens enough to printer a few lines before it re-asserts itself again.
Based on my experience of this printer, if you're using a non-HP delivery system for ink then you should consider replacing the black ink with a dyebase alternative instead of pigment.. Replacing the Black/Yellow printhead and running a number of test prints to purge the pigment ink in the printhead should then result in a clean and more reliable printout in future.
One other vector for problems is the cleaning area and I've found that this can become soiled with excess ink causing cross contamination within the inks of one printhead. As yet I've not found a reliable solution to counter this sort of issue.
Hope this gives some clues and hopefully some ideas of a fix.
Martin
May 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
Cyan Ink cartridge Not printing correctly
After all these tests, then it's defective.
Swap out the cartridge before it damages the printer permanently,
Regards
Ric.
Apr 17, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Yellow not printing - but only in streaks
Your yellow problem sounds like a bad yellow developer housing. Take the drum out and look at the developer housing, You will need a flash light to do so. See if the roller is solid yellow. Even if it is there may not be any developer left in the housing.
The Cyan sounds like the drum since it gets worse as it prints.
That can also be caused by the transfer belt cleaner. But that normally is the opposite. It has a rainbow sort of streak and it gets better as the machine runs.
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
83 people viewed this question
old marine
old marine
