Question about Carrier Access Wide Bank 28 DS3 Multiplexer
I had to replace on of the controllers on a widebank 28 multiplexer. Now we are getting a minor alarm stating that there is a software mismatch. Is there any way to copy the software version from one controller to the other to make them the same?
2 Suggested Answers
SOURCE: I have several Wide Bank
Contact Wayne Chu at 101 Telco Solutions. They can help. w.chu@101telco.com
Posted on Feb 27, 2012
What's your problem?i am facing oblem power alarm and i can not get dial ton on my newbridge 3600 can any body help me to resolve this problem how can i check that
Is this connection between a LGS and LGE card?? if so then the only problem can be on the configuration on the two cards, both needs to be configured for "RE" remote extention.
Regards
Len
Jun 23, 2012 | Alcatel Newbridge MainStreet 3600...
Does anyone have modem setting and cable pin out for a Wide Bank 28?
The pin out is the usual RS-232 (25-Pin TL1 or 9 Pin TL1). If they are not working, check if they got disabled.
You can find the documentation on https://www.force10networks.com/CSPortal20/KnowledgeBase/DOCUMENTATION/T-CA-W_DOCS/WideBank/WB_DS3_243_User_Manual_AT.pdf It also describes how to handle the xmodem.
Mar 14, 2011 | Carrier Access Wide Bank 28 DS3...
Power locks don't work with remote or control from
The door lock/unlock input from the driver's key switch goes to the Door Multiplex control unit (main switch), the Door multiplex control unit then sends a signal on the BUS (CAN) circuit to the passenger's multiplex control unit; the passenger's multiplex control unit then controls all the door locks. The passenger's door lock key switch inputs to the passenger's multiplex control unit, if the locks work from the passenger's side key switch but not the driver's side key switch, the most likely cause is the driver's multiplex control unit (main switch) not sending the signal to the passenger's side multiplex control unit. This could also be the drivers side door lock actuator. Hope this helps!
Jan 07, 2010 | 2003 Honda Pilot
What is E3 code
Hello there:
E3 fault code
Touchpad or Software mismatch Flashes when there is a touchpad or software mismatch. NOTE: This error code is displayed only in diagnostics mode.
Unplug the machine for 30 min and then plug machine back in to clear this fault code
If the code persists the control panel is faulty and will need to be replaced or serviced by a qualified technician
Dec 16, 2009 | Maytag Washing Machines
Resetting clock
in most cases it wants it in a 12 hour format. like(12:28:30-pm) 00:00:00-01= 12:00:00pm
Oct 22, 2009 | GE Security Simon 3 Wireless Home Security...
Can anyone please tell me how to check that which Control Card's IOS (Software) version I have ? Some one told me that Its like release 7 , 8 or 9. Plz tell me cz I want to upgrade my IOS .
When you 're login to system via VT100 or CPSS connection, top of the screen you can see easly the version of CTRL like 1117-H1-xx ...
I think 1117-H1-70 was the latest version for single shelf configuration.
ilker
Jul 03, 2009 | Alcatel Newbridge MainStreet 3600...
Dual E1-3 card say CArd Dead, because has been offen reset. Card Reset alarm declaration parameters is 3, 0, 103. I'm not find in Maintenance this third parameters (103). Help me resolve this problem...
Please insert this card to another slot and then Config -- Slot (not select AsPresent) in the Options selecton, you have to find your card ID_name then procced.
ilker
Dec 05, 2008 | Alcatel Newbridge MainStreet 3600...
Carrier Access Wide Bank 28 DS3 Multiplexer Logo
89 people viewed this question
Top Carrier Computers & Internet Experts
Martin Murray
Paul Carew
Are you a Carrier Computer and Internet Expert? Answer questions, earn points and help others
