Question about Westinghouse Refrigerators
I have a RS643V are the contents in the fridge
I have a RS643V and the contents in the fridge keep freezing also the water dispenser is not working both problems occured overnight
The 643V has an issue that it can freeze the water in the line during winter.
You must switch the fridge off until the water starts to run again. Then set the temperature of the fridge up as high as possible in winter. Draw 1 litre of water at least twice a day during winter.
This fixed my problem.
You can set the tempertaure back down in the fridge during summer without a problem.
Posted on Feb 01, 2011
Water not working, ice is. fridge is set at 2.stuff freezing
i have this exact same problem. Started about 3 months ago with the crisper and now the water. when I turn the fridge off after a few hours the water works again. I'm calling the repair person tomorrow
Jan 30, 2010 | GE Profile Arctica 25.4 Cubic Feet...
My fridge keeps freezing my food
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water dispenser not working, keeps shutting off.
Often if you experience a freeze up it will take less time to refreeze because the tubing never got clear during the defrost originally. Try the defrost again and this time run at least a gallon of water through the water dispenser.
And although you say keep the vent open I have to offer the opposite solution close the vent. Too much cold air from the freezer is getting into the bottom of the fridge. closing the vent should allow the temp to rise. Assuming yours is a manual vent. If it is thermostatically controlled the controls may be at fault or the vent door may be warped or blocked open by ice.
If this helps you reach the next level of solving your problem please rate me as high as you can and thank you for using fixya.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water does not flow through the dispenser
sounds like the sensors are playing up causing the bottom of the fridge to freeze, this will also cause the water reservior to freeze thus no water to the ice tray and water dispensor. do a full defrost then see if you gain back all the functions proving the sensor fault.
Apr 05, 2009 | Frigidaire FRS26R4A Side by Side...
Water dispenser won't shut off nor will the ice dispenser motor
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Electrolux Refrigerators
I have a Hotpoint hss25gfpe ww fridge with ice and water in the door. The ice works, but I am unable to get water. Why can I not get any water? The serial # is tf261776 if this is needed.
Most water dispensing fridges have a tank in the fridge to keep the water cold. If the fridge temp is too low it might freeze the tank and stop the water from dispensing. Also check the water filter to make sure it is not frozen. Water filters should be replaced every 6-12 months, if it's been longer than that it might be too full of dirt to allow water past. It also might be the water inlet valve is not opening.
Jul 20, 2008 | Hotpoint Refrigerators
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
149 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
