Question about Electric Music
The display of my roland XP-80 is Zero, & theres no pragrams or voices, patches display... & the worst is there`s no sound because there is none in the display Pls. kindly give me an advise thank you!!!
    President:
  • 1,137 Answers
The procedure at this link shows you a battery replacement procedure that should work for you:http://ztup.com/Roland-D110-Battery-Replacement-Guide.htm You will need to design new user patches if you didn't back them up.
Posted on Jul 13, 2010
  • jeffrjohnson Mar 30, 2014
    Same issue. Fix worked for me as well. Strange as I just replaced the battery two months ago. Why would it drain so quickly? Had the last battery in it for 6 years!
Muy xp 80 sometimes truns con ok,but sometimes the display stays on blinking with no sounds .could it be the display por power supply?
Posted on Aug 19, 2014
Having a problem with the touch screen with my Roland E80 keyboard work station. Very slow or no change . Please help .
Open up the Roland E-80 and check if all connectors and flatcables are well seated.
Dec 21, 2016 | Roland Music
Tip
RC looper and DR880 syncing.
RC-50 & DR-880 Setup
Rather than using the RC-50 to change patches on the DR-880, I have connected an FS-6 footswitch to both the RC-50 & DR-880. This gives me control of both units, I can select up & down through the patches easily.
Use a dual TRS connector and 2 stereo "y" cables connected to ports 1,2 & 3.4 on both units.
Once connected, you will need to assign the control function for each control port. I assigned Patch Decrease to CLT 1,2 & Patch Increase to CLT 3,4 on both units.
I then connected a MIDI cable from the RC--u control of start/stop & tempo via the RC-50 footswitches.
on Feb 25, 2015 | Roland Boss RC50 Loop station (with )
Will a memory card M256E or M512E that has been programmed on a Roland D110 work on a D5 / D10 / or D20. I have such a card with the RTOM Theatre organs sounds on it, programmed on a d-110?
As I recall, D110 voice programs will tranfer the voice data to D4/10/20 but not D50. However, no setup or performace data will transfer.
However, it's been quite a while since I've used a D110.
Oct 09, 2015 | Roland Music
How do I fix a Roland Digital Piano FP-8 that has refused to play sounds despite the fact that it displays lights?
If everything lights up and responds to button pushes like normal, and you've done a hard reset as described in the manual, check to see if you have sound out of the headphone jack. It's most likely not a user serviceable problem and will need to go to the shop, but it will probably be the output amp rather than the main board.
Mar 07, 2015 | Roland Fp-8 Digital Piano Email Us For A...
Roland pad 80 is it normal for the lcd display to show a bar of squares and nothing else when pluged in to power and not pluged into anything else?
The Roland Pad 80 has a contrast control, if it's not correctly adjusted, it could cause it to appear all black or all blank.
If the LCD were bad, it's uncommon for both sections to both go out around the same time, since it uses two seperate 7 segment LCD components. About the only way to cause both to go out at about the same time, would be to get the equipment wet, or let it get way too hot or left sitting out in the sun, long enough to dry up the "liquid" part of "Liquid chrystal display".
Oct 15, 2013 | Music
I have a Roland AC-90. During a gig last Sunday I had my Taylor acoustic guitar and a Shure mic cutting out. There would be a break in sound - both guitar and voice would go - and then it would all come...
I would expect there is bad soldering or a circuit board crack. Inspect the soldering aound the leads, especially pots and heavy components. Finding all the retaining screws can be frustrating. Expect the screws for the handle to also attach to the amp chasis. They are often hiodden under plastic caps.
May 31, 2011 | Roland Ac-90 Acoustic Chorus Guitar Amp...
Roland XP 50 Head phone not working
Make sure that the level of the headphone out put is open. Make sure it is on manual adjustment and no auto level. And test your headphone on a other device to clear that your headphone is not broken. If all these options are correct you headphone pre amp of the XP 50 may be damaged or broken.
Mar 07, 2010 | Music
RC-50: Importing wav. files from computer to loop station.
Hi I just got a RC 50 and I face the same problem but looking the content of the data in the Roland folder (after you connect the USB) , I notice the format of the label of each sound's and I understood the problem. So , here it is . Before you connect to USB , you have to choose a patch , let say n.16 OK, now the audio file that you want to import into the data folder must be named in this way "016_1.WAV" ,the 16 refer to the patch number and 1 is the phrase number (if you want to put the audio file into the phrase 1 ,or 2 if 2 ecc.) now disconnect the USB .At this point you just have to increase or decrease the patch number just one time and go back to 16 (it has to refresh the patch info) and you'll find your audio file ready to use in whatever phrase you put it.
have fun
Paolo
Jan 19, 2009 | Boss Rc 50
Music Logo
578 people viewed this question
Top Electric Music Experts
GCcontractor
Rob boss
Level 1 Expert
Are you an Electric Music Expert? Answer questions, earn points and help others
