Question about Stanley Bostitch Coil Framing Nailer
Air is coming out of the trigger area on my Bostitch framing nailer.
  • 3 Answers
Firstly tell me what ur Pro..
Posted on Jul 06, 2010
What do I need to replace in my bostitch 28 degree framing nailer?? I shot I one time and now there's air leaking from the trigger area!!
More than likely you need a TVA6 valve it is about a 10minute fix. trigger valve will cost about 20$ on eBay or Amazon
Mar 22, 2015 | Air Tools & Compressors
How do i rebuild my bostitch n80 frameing nailer
Bostitch nailers are simple to rebuild. Bostitch company was sold to Dewalt so parts are now easier to obtain from local Dewalt service center. Use Ork11 oring kit and tva6 trigger valve. These parts are also available on ebay. Good luck or your nailing projects.
Sep 18, 2014 | Stanley Bostitch N80CB Coil Framing Nailer
N88 bostitch nailer fires when connecting air hose
I have seen this on dewalt nailers also, caused by trigger valve worn. on Bostitch nailer part # tva6 remove roll pins retaining trigger and trigger valve. one roll pin for trigger and one or two for valve. With pins removed apply air pressure to gun popping out the valve. Use glove or folded-up shop rag to catch the valve as I pops out. Be sure to reduce air pressure as it could come out with force. Good luck
Jan 20, 2014 | Stanley Bostitch Coil Framing Nailer
Stanley n60 trigger blow by
Sounds like o-rings. Have you tried replacing the o-rings?
Feb 14, 2013 | Stanley Bostitch Coil Framing Nailer
My bostitch n63cp coil framing nailer blows air continuously near the trigger and does not shoot the nail. What is wrong and how can I fix it?
Replace the trigger valve assembly. Part TVA6. It takes just a few minutes. The part will include a pin punchout tool, you supply the hammer.
Jun 28, 2010 | Stanley Bostitch Coil Framing Nailer
N64C GUN HAS A LOT OF AIR COMING OUT OF THE TRIGGER. HOW DO I FIX IT?
This can be caused by a defective o-ring or a trigger. Repalcemetn parts aer available here:
http://www.mastertoolrepair.com/bostitch-n64c-nailer-p-20071.html?osCsid=hl63q31pjjkg5c34jks4im8lh2
The trigger assembly is part # TVA6 and costs $20.
Hope this helps,
Dan
May 19, 2010 | Stanley Bostitch N80CB Coil Framing Nailer
Framing gun not firing leaking air aroung trigger
You have a crumbled trigger seal. You can order a new trigger valve through bostitch. It usually takes a couple of weeks though.. Every time I order one it is on backorder. You will need to order trigger valve kit part number TVA11 $21.40. Go to the Bostitch website click on Schematics and Parts to the left then find your model nailer in the search field and select item 53 when the parts list comes up. Click add to cart to order. Another screen will pop up and ask you if you want to checkout. Any questions please post back.
Oct 15, 2009 | Stanley Bostitch N88rh Framing Nailer...
Stanley finsish nailer and air is leaking through the trigger as.
If the air is coming out the trigger it must be replaced. Depending on the model of gun you will have to replace the trigger assembly or various o-Rings. Find a Bostitch dealer in your area and they will supply the parts you require.
Jul 14, 2009 | Stanley Bostitch FN16250K - 2 16 - Gauge...
N80sb-1 stanley bostitch framing gun.
Yes your nailer will drive other sizes of nails. For info and parts go to www.bostitch.com and look for the support tab then select service parts. Here you will find parts list and manual. To remove the tva11 trigger valve remove the retainer pin (the pin is 3mm) for the trigger and remove trigger. Next remove roll pin/pins that retain trigger valve. Use heavy glove to catch trigger valve as you apply air pressure to gun. The valve could pop out with great force so try lowering the pressure to gun. Before installing the new valve, check the opening for sharp edges which will cut orings. Good Luck and email if you have more questions.
Mar 14, 2009 | Stanley Air Tools & Compressors
Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Jan 05, 2009 | Stanley Bostitch Coil Framing Nailer
Stanley Bostitch Coil Framing Nailer Logo
152 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
