Question about Navman iCN 330 GPS Receiver
How to replace internal battery for Navman icn330. Does the cover come off easily and how?
  • Clockmanuk Jul 23, 2010
    Sorry, This information is incorrect!
    I now know how to take apart this unit which is secured by four screws not mentioned in the solution given.
  • 11,800 Answers
Taking out the back cover will be hard - there are a lot of moulded clips on the periphery, you must gently pry them open with a thin blade one at a time; Start at the bottom, next to the speaker and go all around except for the left side (the one with the card) there it will just lift out when you rotate the back cover. Be sure not to rip the antenna connections and do not force it or the back cover will split.
Posted on Jul 06, 2010
Www navman com manuals
Rechargeable battery life is not infinite. A few houndered times is about all you get on average. How deeply you let it discharge, the temperature of the space that it is in, how long you let it charge, etc. all affect the number of charge / discharge cycles it can provide.
You should probably have the battery replaced - or if too costly, stick with direct power only.
May 24, 2013 | GPS
F20 GPS
Remove memory and put it back, if it still does not work memory is probably faulty.
May 24, 2008 | Navman F20 GPS Receiver
Need operators instructions for icn330
You may download a copy of the manual here.
Oct 07, 2012 | Navman iCN 330 GPS Receiver
Does the same apply for the NavMan S100T battery as you can buy replacement batteries for this model?
No. From the manual: "Your Navman contains a non-replaceable internal lithium-ion polymer battery."
Mar 05, 2012 | Navman GPS
How to change battery Navman icn 330
hi location inbrisbane to buy new battery for 330icn navman thanks
Jun 21, 2009 | Navman iCN 330 GPS Receiver
External Antenna Conection
Ref ICN330. The external antenna connection is on the top side of the flip up Antenna on the unit itself. There is a small rubber plug covering this, adjacent to the Navman logo.. Ricmac
Feb 12, 2009 | Navman iCN 330 GPS Receiver
Info on fitting a new battery to Navman PiN570
Remove SD card and place the Navman on a soft surface face down so that you do not scratch the LCD screen. - Take out 4 screws ONLY. 2 under the gps antenna and two hidden black discs at either side of the bottom on back of unit,Make sure you use a small Philips screwdriver.
- Use your finger nail very carefully around the edges, go extremely slow to detach the cover. Once it opens, make sure of the Power switch button, they seem to fall off.
- Remove clear tapes at the battery connector. DO NOT pull up the connector, you need to pull sideways and make sure do not use excessive pressure while pulling.
- Place the new battery in same manner and also place battery cables neatly so that the do not come in the way while closing the cover. The LCD display should turn on. If it does not, look at the Battery connector and make sure it is all the way in.
- Put the cover back slowly and then make sure nothing is dangling along the edges. Do not forget to check the Power Switch button; it should be in proper place. Press the cover firmly, it should snap in place.
- Charge the battery fully before using Navman.
- Insert SD card. You may need to reload Navman application software or restore from SD card, if you stored on the SD card previously.
May 16, 2008 | Navman PiN 570 GPS Receiver
Navman icn 320
carefully pull off front grey cover with your thumb, next to card socket, underneath are 4 security screws you need a small torque head screwdriver, take off cover losen security screws inside around battery, unplug and remove battery, replace in reverse.
Jan 03, 2008 | Navman iCN 320 GPS Receiver
Navman iCN 330 GPS Receiver Logo
125 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
