Canon I900D InkJet Photo Printer Logo
A
Anonymous Posted on Jun 20, 2010
I am trying to print a pdf document on my Canon Pixma i500 and it won't print
Lucy Li
Level 2:
  • Expert 85 Answers
  • Posted on Dec 08, 2013
Lucy Li
Expert
Level 2:
Answers
85
Questions
Helped
30990
Points
174
Unbelievable, it is so easy to remove PDF password restriction on PDF Password Remover. Only in 2 steps, it is done.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
1730
Points
8
Hi, make sure if the pdf is restricted by owner password which prevents you from copying, editing and printing pdf files. User a pdf password remover to remove pdf password. AnyBizSoft has a product like this.
How do I get my Canon MP2520 printer to print pdf files?
Try with following tips
1. In the print dialog, click on the Advanced button (lower left)
2. Check the box to "Print as Image".
1helpful
I set something up to print and it only prints a half a page
Can you save your document to PDF and try to print it again? Sometimes there is 'corrupt' postscript information in your file, and when you make a PDF first, it will be solved. If you do not want to make a PDF first, try to print your document page by page. It also could be a memory problem. That sometimes will be solved by shutting down your printer, wait a minute than switch it on again. So, you can try these three things:
1: Shut down your printer, wait a minute switch it on again, than try to print your document
2: Print your document page by page
3: Make a pdf of your document first, than print the pdf
Succes!
Printer is online, but status is offline
Hi, make sure if the pdf you can't print is restricted by owner password which prevents you from copying, editing and printing pdf files. User a pdf password remover to remove pdf password. AnyBizSoft has a product like this.
When I send my Word 2007 document to my Canon PIXMA IP3000 printer it won't print from the cassette tray but wants to default to the hand feed. When I run a printer test page it works fine. When I first...
Go on Canon web site and look for updated drivers for your operating system.  Also get updated drivers for your word 07 by clicking on check for updates in one of the top tabs when you got Word open.
Cannot print pdf
Can you printer other kinds of documents aside of PDF?
Maybe you have something in the PDF that is causing an issue with the printer. Will the PDFs print on you mom's older printer?
Type of document usually doesn't have any bearing.
An incorrect driver perhaps. Go to Canon's website and locate the latest driver and any updates for your model.
I have a Canon PIXMA MP780. It won't print except
If you can print the nozzle test then that proves most of the electronics, it could be the driver is screwed.
Since you can get something out that is intelligent e.g. the larger font lettering then it is processing the file sent to it.
By that I mean rasterising it, converting it to dots of ink, so it can print onto the page as the heads moves back and forth.
Why not try another computer and connect your printer to that one, or try a different file, or even send it a file you've printed successfully in the past before you started to have this problem.
Printing only upper part of page - big graphic PDF
1: check in the printer properties( page setup ) is it latter then make it A4
2: clean the roller
3: also when u printting check with uper try not from try 2
if its printing proper then try is touching roller
PDF FILES
When you print on the PDF, before you will start printing check the settings of the printer. You can see the printer named? find the printer you are using.
old marine
old marine
ZJ Limited
ZJ Limited
