Question about HP w1907 LCD Monitor
I need fix this problem about '' monitor going to sleep''
Hi my name is cassandra
ill like help on my hp w1907 it reqires me an attention that the keeps on turning off and saying ''monitor going to sleep''. how can i fix solution? do i go into the system and chang it? do i go the profesionals and get help?
  • 304 Answers
To resolve the issue, please follow the steps mentioned below:
1) Go to Control Panel, click on "System".
2) Then, click on "System Protection".
3) Then, click on the "Advanced" tab.
4) Then, click on the "settings" under Performance.
5) Then, select the "Data Execution Prevention" tab.
6) This is where you can disable the "explorer.exe has stopped working".
7) In the Data Execution Prevention tab, select "Turn ON DEP for all programs and services except those I select" option.
8) Then, click on the "Add" option.
9) Then, you have to select the explorer.exe file manually.
10) the "explorer.exe" file will be located in the C:\Windows folder.
This might be a lengthy process, but this will resolve the issue.
If you have any difficulties, you may contact me through my Email address.
suresh0954@gmail.com
Posted on Jul 06, 2010
Why does my monitor keep going to sleep when i am using pc
Go to Control Panel --. Power Option --> Change the settings[you may need to click on Advance settings if you are using windows 7] for Sleep After to "Never"
Mar 12, 2011 | HP w1907 LCD Monitor
No vga input/dvi input monitor going to sleep. irksome! can somebody give the appropriate solution. tns.
When i turn my computer on my monitor keeps saying no vga input and no dvi input then the monitor says going to sleep ..........PLEASE HELP ME!!!
Feb 10, 2011 | HP w1907 LCD Monitor
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
Monitor Hp w1907 has no input signal, how do I get connected and keep it from going to sleep
If you set the PC to go to sleep after certian amount of time than it will not put out signal to the monitor. You need to go to display properties (right click on the desk top)/screen saver -power/set the display to never turn off.
Nov 30, 2009 | HP w1907 LCD Monitor
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
HP w1907 monitor going to sleeep
Check your owners manual for the power saving controls. In this section this should explain how to stop the monitor from going to sleep, or at least allow you to to set the timing for it. If this does not work visit the HP website and search the common problems for your model of monitor. search for this problem and the solution.If all this fails, seek help from HP technical service. Hope this helps.
Apr 14, 2009 | HP w1907 LCD Monitor
Disable sleep mode
For XP: Start>Control Panel>Power Options>Click the options you would like under the Power Schemes/Advanced and Hibernate. Vista may be a little different but it is still under Control Panel and Power
Don't forget to rate this solution with 4 diamonds.
Feb 22, 2009 | HP w1907 LCD Monitor
HP w1907 LCD Monitor Logo
553 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
