Dell 23'' TV/Monitor has stripe of raster in screen, just to the left of center. Comes and goes, sometimes it's just wavy, sometimes it's completely black.
  • wilkerbeast0 Jul 06, 2010
    @Ambari: Thank you very much for the reply. I forgot to mention that it is an LCD unit (2306, I believe).
  • 901 Answers
Check main power supply DC capacitor.If this becomes dry this wiil fault could be due to intermittent contact of the EHT at picture tube body. Other possible fa Remove and reconnect the EHT cable at picture tube end. Before attempting switch off T V. Remove all electrical plug connections. Wait for few minutes for the EHT to discharge. Ease the suction cup that is hugging the picture tube body. By keeping the circular flaps folded by finger try removing the folded pin clip that is on the glass body. Clean and re position the clip. Attach back the suction clip.
Take care high voltage present at picture tube even the TV is OFF and plugs removed.
Posted on Jul 06, 2010
  • Ambari Jul 07, 2010
    For LCD TV.
    You have to check all the DC voltages first. If they are OK , check for any loose connectors. Remove and re connect the connectors. SMD components can not be repaired without special soldering tools. Take the help of the service providier for further repairs.
The right side of the screen sometimes has veritical stripes or goes black and then comes back to full screen after time passes.
There is 1 or 2 flat cables that connect to the main circuit board to the t conn board at the top center back of screen. press these in . This may fix. If not replaced the LCD panel . probably cheaper to replace the tv.
Aug 30, 2011 | Samsung LN52A550 LCD TV
Someone gave me a dell w3000 tv and i hooked up the speakers and cable line and plugged in. the tv button turns on and green light comes on but no picture or sound
I have this tv, and have had the EXACT problem. my solution was simple. just need patience if you take the back cover off of the monitor, there are 2 boards on the outside edges of the left and right of the monitor. these boards are covered by metal shields. remove the 3 screws on each board shield and slide them off.(careful this can be tricky) on the boards are 2 capacitors that need to be replaced. 4 total, 2 on each board. the capacitors are 150uf at 35 Volts. go to your local electronics repair shop to get the parts and tools needed to do this repair.
make sure to get the polarity of these caps right. stripe side on cap goes to the minus.
Aug 04, 2010 | Dell W3000 30 in. HD-Ready LCD Television
Yellow Stripe Down Middle of Screen on Laptop
This system has a VGA port so you can plug in an external monitor. You can buy one for less than $130 based on the Sunday ads. Other than that, it is new laptop time.
Jul 31, 2010 | Acer Computers & Internet
Hi there, i have a Dell tv model W3000 lately the tv does not turn on at all,i know power is there but the tv does not comes on. sometimes it comes on but it does not last....if i turn the tv off it does...
This is the way all of these fail. Don't buy Dell TV's.
Try this internet posted solution.
Turn on TV with remote control, if the TV does not light-up, find the Main Power Switch. Turn the switch off, then turn it on, the TV lights-up. Probably caused by poor contacts due to age and low quality parts.
Apr 27, 2010 | Dell W3000 30 in. HD-Ready LCD Television
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
Picture stripe down center of screen
Is the stripe there when the machine boots up in dos or only when it goes into windows? If only in windows the I suspect a driver problem. If all the time I suspect that the LCD panel itself has gone bad.
Jun 06, 2008 | Dell D1728D-LS VS17X Monitor
Centering your monitor screen
Check your resolution and change them. This happens sometimes when a monitor can not handle certain resolutions.
May 29, 2008 | Computers & Internet
Pink horizontal stripes on my monitor
If youve tried pressing the degaus button on the monitor and the same result then either your graphics driver is corrupt and needs to be updated from the manufacturer web site or the monitor is on it's way out. Try a friends monitor on your system or your monitor on a friends, if it's the same on a friends ststem, it's a belated Xmas present for yourself.
Dec 30, 2006 | Samsung 793DF 17" CRT Monitor
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
