Question about Motorola Mobility ROKR E6 Smartphone
My mobile mic not working how to repair it - Motorola Mobility ROKR E6 Smartphone
Mic not working in 6070 what should i do
Your only option is to get it replaced. First of all, try with you headset and verify that the Mic on your headset is working. This is to make sure that there's no other issue with your phone. Sometimes when the sound IC is faulty, this might happen, but in most cases, it's the mic itself. If you are not a technician or mobile repair tech, you'll need to visit a Nokia Care or a mobile repair shop to get it replace. Hope this helps.
Good Luck.
Thanks for using FixYa.
Sep 01, 2011 | Nokia 6070 Cellular Phone
My blackberry 8100 will make calls and I can hear them but they cannot hear me
Your mobile is having some problem with it.
If's a small problem.
It can be fixed.
Your mobile mic has some problem.
For that you need to visit your nearest service center.
There they will change your mobile mic in a few seconds.
If you change the mic you can use your mobile then you will not face any problem.
After repair check weather it is working correct or not.
Thanks for your question.
Jun 30, 2011 | Cell Phones
SAMSUNG JET 8000 I CAN HEAR MYSELF IN MY EARPIECE BUT THE OTHER PERSON CANNOT HEAR ME...DOES IT NEED GO IN SHOP 4 REPAIR???????? THNX
Mic problem,Yeah u need to visit a mobile shop they will repair and give u the parts are minor so.Cost will be less.
Jul 13, 2010 | Samsung Jet S8000 Cell Phone
I have a nokia 1110 model ,phone is ok but the mic is not working ,what should i do now tell me the solution
If there's no internal problem like circuit or ic issues, your problem will be fixed after replacing the mic. You can get the mic from any mobile repairing shop or from mobile spares shop. There's a specific mic for your model, but if in case, you can't find one for 1110 model, then get a universal mic (small), you'll need a soldering iron with soldering wire and paste. If you now how to use mobile soldering iron, go ahead but if you are not good at it, i would suggest you to get it done from a mobile repairing shop. A small mistake can lead to permanent damage and unrepairable.
Good luck.
Jun 23, 2010 | Nokia 1110 Cellular Phone
Mic not working
There's no other solution other than replacing the mic. You better visit a mobile repairing shop and get it repaired. They'll charge you few bucks for the mic and for the services. Good luck Thanks for using FixYa.
Jun 04, 2010 | Nokia 5200 Cellular Phone
The Cherry Mobile D23 all of the sudden the mic doesn't work. The Caller can't hear my voice but I hear them well on the ear piece. When I use a headset it works fine. It must be the mic on the handset...
You have made it clear, your problem is with the mic. If you know how to replace it you can give a try, otherwise i would recommend you to take it to the repairing shop and get it repaired. It's will cost a maximum of $10 (rate varies with countries) including service charge. Universal Mic is the best, so if you buy one, ask for a universal mic. Good luck.
May 10, 2010 | Cell Phones
The other person can't hear me
the problem is of ur mic u can get it done through mobile repair shop...
Sep 09, 2009 | LG KG800 Cellular Phone
How to solve the nokia 5300 mobile mic problem
the mic in the 5300 handsets have a big problem where nokia used cheap mics and they stop working after a while
get this replaced at a respectable mobile phone repair centre
thank you
Michael
Universal Mobiles Coventry LTD
(Mobile Phone Engineer)
May 27, 2009 | Nokia 5200 Cellular Phone
Motorola Mobility ROKR E6 Smartphone Logo
80 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
