Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer Door Locked
It does not open. Please advise
  • bearmomof5 May 15, 2008
    Neptune door locked shut mid -load. Washer needs new computer. how do we get the door open without replacing computer? We are getting new machine just need wash out from in it.
  • Anonymous Mar 17, 2014
    The door lock will not release.
INSIDE THE SOAP LOADER THERE IS A LIME COLOR STRING PULL IT WILL UNLOCK LATCH
Posted on May 18, 2008
My maytag front loader door is locked and will not open, was in the middle of spinning made sound and could not open door to restart
Posted on May 13, 2008
5 Suggested Answers
  • 34 Answers
SOURCE: Maytag Neptune washer error FL
There is a manual door release tab in the dispenser area. You have to take the screws out and remove the dispenser to pull the tab and release the door. This is a pretty common issue, if you haven't yet you should contact your Maytag authorized dealer and ask about a more permanent solution. Hope you can get your clothes out.
Thanks
Posted on Apr 30, 2009
johnychel
  • 796 Answers
SOURCE: Maytag Neptune Washer Door Locked
the sensor is not working properly
  • 5 Answers
SOURCE: Maytag Neptune door lock stuck!!!
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
Posted on Jul 10, 2009
oldmanewtoys
  • 414 Answers
SOURCE: mah4000aww no door locked light
The lid/door safety switch needs replaced
Posted on Mar 08, 2010
Front-end door is locked. Can't open it.
Yes there is a plastic lead inside front of soap powder dispenser. Sometimes you have to remove screws from dispenser to gain access to it. JUST PULL IT & THE DOOR WILL OPEN.
Dec 19, 2013 | Maytag Neptune MAH6700A Front Load Washer
Door won't open
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/27966-maytag-mah5500b-fl-code-door-locked.html
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/13490-maytag-neptune-mah5500-wont-open.html
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
Try these steps:
Jul 01, 2009 | Maytag MAH6700AWW Neptune Front-Load...
MAYTAG NEPTUNE DOOR LOCKED WILL NOT OPEN!
The comment posted 14 may 2009 it what helped me. DO NOT PRY OPEN the door. Find the release cord inside the soap dispenser,,,you may have to remove the 4 screws and lift it from the washer like i did. I had to lean into the door and pull the cord to release the lock. It was not a system error. The washer was over loaded and although the door was closed and locked...the load pushed the door enough to indicate that it was open and would not wash. After opening the door, rearranging the load and removing some, the door closed and latched locked and was able to continue with the wash. DO NOT PRY OPEN,,,use the cord release first,,,this worked for me.
May 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag front end loading washer is stuck locked
Open the detergen/bleach diospenser cover and there is a tab there that you can pull to open the door. You will likely need to replace the wax motor and control board.
Apr 07, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune front load washer with FL code
The "FL" is indicating that the door has failed to lock or it locked but the control does not sense the door has locked.
It could be caused by:
faulty door lock solenoid
loose wire connection
faulty door lock switch
faulty door lock sense switch
bad control board
I recommend calling a service technician to diagnose and repair your washer.
but try this first just in case....unplug it for 1 minute plug back in and see if the fault code clears.
good luck.
Jan 03, 2018 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
1,296 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
