Question about Bissell 6594 PowerForce Bagless Upright Vacuum
No sucking the dust
Still very new i cleaned the filter twice and it does not vacuum well help
  • 24 Answers
Check the pipe up from the brush to the pump that it has not been blocked by an item too big to go through to the catcher
Posted on Jul 06, 2010
Hi my Bissell 3750e has started making a loud rumbling noise when I push it. I've cleaned all of the filters the belt is fine and the suction is spot on. When I push it I can also smell a burning smell any ideas?
Posted on Aug 28, 2010
2 Suggested Answers
  • 694 Answers
SOURCE: Unbeknownst to me, someone took
Sounds like you need to buy a new motor. All that grit and dust will ruin a motor and I'm surprised it lasted as long as it did.
This is where a vacuum that won't run without a bag would have been nice. (Aerus for one)
Posted on Nov 16, 2010
Hoover not sucking
Remove all filters and try the suction on your hand, NOT THE FLOOR!
Filters are vital to keeping the motor working.
Most vacuum sucking probs are a result of a clogged filter or filters. Sometimes, hoses also. Or a full bag.
Remove all filters, clean them thoroughly, check hose for obstruction.
Use another vacuum to remove dust/dirt (or an air compressor) from the dirty filters.
That's first step.
Feb 26, 2015 | Hoover Vacuums
Vacuum appears to be blowing dust out rather than sucking up dust
Check Hepa Filter if it has one or other resevoir for excess dust/dirt. Clean receptacle and replace filter.
Sep 23, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
Doesn't seem to be sucking up dirt well
Bagless vacuum cleaners leave the bulk dirt in a receiver, but they still rely on a paper air filter to trap fine particles of dust. All the air that the vacuum moves passes through that paper filter. When the filter plugs up, it has to be cleaned or replaced. The bagless "primary filters" are much more expensive than vacuum cleaner bags, but if you can afford to replace it whenever the machine's suction is impeded, its the tidyest solution. You can remove the filter and tap it inside a waste can to dislodge some of the dirt that's plugging it. You can use another vacuum cleaner to clean it somewhat better than just tapping it. (It doesn't have to be *your* other vacuum cleaner, it could be borrowed, at the car wash, etc.) You can use compressed air to almost all of of the dirt plugging it, but you'll want to do it outside somewhere that making a clod of dust is acceptable or at least unnoticed. After a dozen or more cleanings the pores of the paper filter will become too plugged to clean well even with compressed air and it will have to be replaced.
Pet hair, sand and large particulate are least likely to plug these filters. Kitty littler, which is pressed pellets of fine clay, clogs these filters very rapidly. The clay pellets break up into very fine dust as they pass through the vacuum and whirl in the dirt cannister. Avoid vacuuming kitty litter, or any other fine clay into a bagless machine as much as possible.
Jul 28, 2012 | Hoover S3765-040 WindTunnel Bagless...
My dyson 24 ball stopped sucking up
Hello, this is Ava with Think Crucial.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 15, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
I have a craftsman 2 gal wet/dry vacuume & after using it for a wet pick up without a filter, it blows dust out while vacuuming and is extremely loud. Any suggestions. I took it apart and unclogged...
It sucked up some of the muddy water into the impeller while you was using it. Then it dried out and turned to dust. After you get done using it for wet pickup take a water hose and let a little clean water **** into the impeller, with it off the tub. That will clean it then let it run till dry. That will keep it from getting moldy also. And always put a filter on before using for dry stuff. They make a universal filter that is like a satin bag. That is what I use instead of paper one. Even for water.
Dec 17, 2010 | Craftsman 17762 Wet/Dry Vacuum
Unbeknownst to me, someone took the bag out of my Kenmore Progressive vacuum and failed to replace it. I have been vacuuming without a bag for months, and today the vacuum stopped sucking. When I opened...
Nov 16, 2010 | Kenmore 31913 Progressive Direct Drive...
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
No sucking
Could be that the dust cup filter is clogged, part #60958, or the inlet down by the brush roll is clogged.
Oct 01, 2007 | Eureka 402A Bagless Upright Vacuum
Bissell powerforce bagless upright vacuum 6594-w
Be sure when you put the dirtant dust container in place that it is in properly. I have had this and believe it or not this container has enough room to fit without it seating properly. Take the dust container out and reseat it making sure the bottom is secure and then turn the lock lever in place. Try it again. What happens is you get an air gap which allows some air to flow but the vacum does not function properly.
desmjs
Aug 26, 2007 | Bissell 6594 PowerForce Bagless Upright...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
604 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
