How do I change the batteries on a PAKP003 wirlesee mini mouse
  • nick272 May 11, 2008
    Thanks for help, fixed my problem..
    Genius:
  • 1,142 Answers
Please refer to this link and you will be able to replace the battery easily
http://www.targus.com/us/Downloads/PAWM001U_UG.pdf
Please dont forget to rate fixya
Posted on Apr 18, 2008
How to change batteries to mini optical mouse
There are no batteries. It's a wired USB mouse.
Apr 26, 2014 | iHome Optical Mini Travel Mouse W...
I have Targu Laptop Remote Mouse #Pakp003, and I want to change batteries as it is not responding to my Kensington Usb adapter. How do I change batteries as havent used for 1 yr.
I discovered you had to push top of mouse near the rolling click, and then slide off cover towards the back of mouse. I earlier thought the battery access must have been on bottom of mouse.
Jan 27, 2010 | Targus (PAUM31U) Remote Mouse
How do I change the AAA batteries in my GE Wireless Optical Mini Mouse
Grip the sides of the mouse with both hands and slide the battery cover
back with both thumbs. Then, replace the old batteries with two AAA batteries. Replace the battery cover. Hope that helps.
Jul 30, 2009 | GE Wireless Optical Mini Mouse 3087897985
Change batteries in a targus portable mouse
I found the user guide in French. It says to slide back the cover behind the Logo on top.
also found it in English:
Installing the Batteries
Optical Mouse
1 Remove the battery cover from the top of the mouse by
pressing the top center (over the Targus logo) and
sliding it back.
2 Insert the supplied batteries , making sure that the
positive (+) and negative (-) ends of each battery match
the polarity indicators inside the battery housing.
WARNINGS: When replacing the batteries, you may use
alkaline or other heavy-duty NiMH batteries. Never
combine an alkaline with a NiMH battery in a device.
Avoid mixing new and used batteries in a device.
3 Slide the battery cover back in to position until it “clicks”
firmly into place.
4 Turn on the mouse by sliding the on/off switch on the
bottom of the mouse to the “on” position.
The optical sensor, located on the bottom of the mouse,
glows red.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 07, 2009 | Targus PAWM001U Mouse
Battery change for model 98792 wireless GE mouse
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Jan 12, 2009 | GE Wireless Optical Mini Mouse 3087897985
Change batteries
This is a deceptive little beastie. As you look at the mouse, you will see that the front approximately 1/3 consists of the left and right mouse buttons and the scroll wheel. The rest appears to be a one piece cover with the black area with the GE logo in the middle. There's the tricky part. The black part with the Logo is the housing for the USB plug in part (so you can keep it with the mouse when transporting it). The rest of that (silver on my mouse) is the battery cover. You open it up by gripping the little raised line on each side of the cover and pull backwards while holding the front by the black area under the mouse buttons. The cover (only the silver part, the black is attached to the rest of the mouse) will slide backwards and Voila! There are your batteries.
Jan 12, 2009 | GE Optical Mini Mouse ho98094
My USB plug in for my GE wireless optical mini mouse
There should be a button on the usb itself.You can try removing it plugging it back in then push that button if still red then you can try changing the batteries.
Dec 29, 2008 | GE Optical Mini Mouse ho98094
Change batteries in my wireless mouse
There should be a battery compartment on the bottom of your mouse. It might have a small screw holding it in place. Open & remove old battery, replace with fresh battery. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | Computers & Internet
Mouse
Do not use a mouse pad with this mini mouse. Battery will last much longer. I have had this mini mouse for about a year with no problems. Recently, though, after changing batteries, I found that the USB connector fails on and off. I have to pull out the USB connection and put it back in again. However, I am having to do this several times a day.
Oct 30, 2007 | Computers & Internet
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
