Question about HP f2105 21" LCD Monitor
How do you open up the back of a monitor on a hp?
    Problem Solver:
  • 17 Answers
ARE U ENGINEER, IF NO.SO PLS DON,T OPEN OF YOUR MONITOR.
Posted on Jul 06, 2010
I have a hp-f1523h flat panel monitor i need to know how to open up so i can replace the video cable
lay down face down on table,unscrew all screws in back,leave them in the back,lift the back off and replace cable
Jun 22, 2014 | HP Pavilion F1523 15" LCD Monitor
How do i open my hpl706 monitor. i need to replace a capacitor
Reomove the base and all the screws in the back, use thin flat blade screw driver to crack open at the bottom edge of the monitor and then work your way around, you should ahve the monitor face down on a flat soft surface.
See example here: http://s807.photobucket.com/albums/yy352/budm/HP%20VS19D/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 02, 2010 | HP L1706 17" LCD Monitor
My computer starts up but my monitor stays in sleep mode i have an hp w 1907 flat panel monitor and my CPU is a HP pavilion
First, ry this monitor on other PC to find out if it is monitor problems or PC Video card problem.
Please post back so we can guid you further.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 10, 2010 | HP W19b LCD Monitor
My hp monitor keeps going dark every time i turn off the monitor and the whole computer but i can still see the background of my monitor but it keeps going dark
Please read below if you are going to DIY repair so you will know what to look for inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 10, 2010 | HP Vs17 17" LCD Flat Panel Monitor
How can i open an hp w2207 monitor
I just got my son's hp w2207 apart. You need to gently pull off the front black frame around the LCD first. Work the black frame away from the silver edging around the entire screen. Then unscrew the four, black screws on the back.
Nov 30, 2009 | HP w2207 Monitor
HP vs15 no problem
Please check first if your LCD monitor is still under Warranty period, if yes, then I recommend to bring the unit to authorized service center to properly diagnose & fix the problem, because if you open it yourself & probably broken its seal then the Warranty will be Void & other problem/s that may arise / found will no longer be covered by their free service / part replacement.
If no longer covered by a Warranty, then you can open it by yourself, by turning (counterclockwise) its lock screws to open its back cover & check the power button connections if loose/broken. regards
May 15, 2009 | HP Vs17 17" LCD Flat Panel Monitor
How do you remove the back or open an HPf1903 monitor?
http://www.instructables.com/id/How-to-Take-Apart-a-Laptop/
Feb 11, 2009 | HP Pavilion F1703 17" LCD Monitor
HP F1930 Capacitors
This is how I learned to open my f1703hp monitor not sure if f1903 hp is the same...I got my open and going to replace power board waiting for the mail LOL.
http://www.fixya.com/support/t862133-open_f1703
Jan 20, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
How can I open the HP w1907 LCD Monitor
I have just opened an HP W1907. It does not open from the back like Dell!!! The black plastic bezel with the HP logo on the front must be removed.I pried mine lose and broke most of the plastic nibs that hold it in place. From examining the bezel, it appears the a thin hook should be slipped in between it and the light gray plastic then pry up the back of the black bezel. The nibs on the black plastic bezel are facing downward and you must somehow lift them up and over the matching locks on gray piece. If you pry on the black back piece, as in Dell, you will break off four post the have screws put in from the front.
I hope this helps.
NKN
Sep 08, 2008 | HP Compaq WF1907 Monitor
HP f2105 21" LCD Monitor Logo
97 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
