Question about Refrigerators
I purchased a fridge in Dec. 2009 model PGSS5NFXB ss and am already replacing the fan for a second time(the fan was broken on day one).is there a history of problems with this model?
SOURCE: thermokool mr-138
is it possible to send a picture of the fan its possible to obtain a universal fan motor that mes to fit many unpopular and popular models in comes w/adadters to fit almost any refrig-
Posted on Jan 09, 2008
Tro_EX
  • 19 Answers
SOURCE: Fridge stays cold most of the time, but sometimes just warms up, then goes cold again. Fan runs during both periods.
I think your refrigerator has a auto run feature.
Posted on May 13, 2009
SOURCE: 6 year old dead fridge!
Nope, the fridge was in defrost mode. had sears home repair tech out who showed me the defrost timer on inside top of fridge side compartment. wish my manual had pointed that out! back in business.
PS. used a leaf blower to remove 6 years of dust buildup underneath as nothing else would do it. what a mess
Posted on Jun 13, 2009
SOURCE: Our fridge/freezer just randomly switches
Unless its not cooling correctly, dont worry about it, might need to blow out conenser coil with compressed air, outside though!!
Posted on Nov 01, 2010
heatman101
  • 43501 Answers
SOURCE: ge fridge pss26sgrc ss is making a
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 06, 2011
P0014 Diagnostic code, already replaced camshaft actuator & oil twice
code p0014 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
forums.trailvoy.com > ... > OEM Issues
Sep 8, 2007 - 11 posts - ‎8 authors
On my Trailblazer I have a code P0014 . this says Camshaft Position Actuator B ... If the desired and actual cam phase angle error exceeds its ... This diagnostic procedure supports the following DTC: ... replace the camshaft actuator solenoid, change the engine oil and filter, ... 2004 Chevy TrailBlazer LT P0014 - Camshaft Position Actuator Solenoid "Relearn"
Dec 11, 2009
cam crank sensor mismatch
Jul 4, 2009
More results from forums.trailvoy.com
Tech Code "dtc P0014" 2003 Trailblazer - Chevy S-10/Blazer ...
www.gm-trucks.com/.../72278-tech-code-dtc-p0014-2003-trailblazer/
Dec 31, 2007 - 14 posts - ‎6 authors
Tech Code "dtc P0014" 2003 Trailblazer - posted in Chevy ... it had been serviced before for the same thing in 2003 or 2004! ... replace the camshaft actuator solenoid, change the engine oil and .... The extended war. co. prob. would not be to happy since they already fixed the sensor once or twice already.
Replace a Camshaft Position Actuator Solenoid Valve on a ...
? 8:05
https://www.youtube.com/watch?v=4Dkdd287AKg
Jan 11, 2016 | 2004 GMC Canyon
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
I have a frigidaire fridge model # FSC238F7DSBA I had a blinking error of " E F" on the control panel. I checked out the error codes as well as called frigidare customer service and they both led me to...
After replacing the control board did you unplugged the fridge.?There is no resetting button.Unplugging the fridge for 1 hour will reset it.If still the fridge doesn't reset then leave it over night unplugged.
Thank you
Oct 19, 2010 | Frigidaire Refrigerators
Up box freezer works fine but low box refrigerator doesn't work
Good day,
2 hours isn't enough time. Doors open, unplugged, minimum of 24 hours, Ideally with a floor fan blowing into the machine.
Jan 15, 2010 | Kenmore 64802 Top Freezer Refrigerator
My 9 yr old Kenmore Elite fridge is warming up!! The freezer is fine!!!! Model 3 106*74902401 Seriel # ES423704 Manufacture date is 10/2005, I purchased it in Dec of '05 and it's been WONDERFUL!!
This problem sounds like a damper control broken or frozen.
Lowering the freezer temperature may help to fix the problem as the damper sometimes freezes and not able to open to cool down the fridge side.
If lowering the freezer temperature doesn't help, you may need to call for a technician to fix or replace the damper control.
Also, be sure the door closes properly and no air comes in or out from the fridge.
Dec 18, 2009 | Computers & Internet
GE side by side - upper freezer warming once a week then freezing
Had the same problem. Bottom of freezer was about the right temp but the upper part was way too warm. Fridge side was fine. Ice maker stopped making ice - it wasn't broken, but it won't run through its cycle if the temp is too high. Cubes already in storage hopper melted and water refroze as it ran to lower, colder part of fridge. Problem: Fan controller for freezer compartment was faulty. The fan itself was fine. Fix: GE replaced the main circuit board that controls everything on this model, including the freezer compartment fan. Once that was done, temp returned to normal, ice maker is happy again. The board had undergone several revisions from the factory installed one (could tell this by comparing the part number on the old and new boards - they increment it when they revise it.) Bad news: the part/labor were expensive and of course failed after the warranty ran out. Good news: the board is now guaranteed for 5 yrs. (Why wouldn't the factory-installed board ALSO be good for five years instead of just one? It's not like the replacement boards are made better.) Labor is covered only for 90 days though so it won't be free if they have to come back after that.
Mar 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Jul 28, 2008 | Refrigerators
DEC Dishwasher
I have a manual if you still would like a copy
Apr 04, 2008 | Dishwashers
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
