Question about Whirlwind FH-778 Air Conditioner
I would like to know the correct way to take freon r22 out of an unit..
  • 29 Answers
You must have a reclaim machine and a reclaim tank and the old refrigerant must be taken to an approved EPA site for recycling.
Posted on Jul 06, 2010
Which gas are refill in 210 whirlpool fridge
Hello Arushdeep Singh,
I have tried to find a "210" whirlpool,..
Sadly only finding some vague references to a
17 cubic foot OLD TIME refrigerator... (?).
The good news: If indeed you are speaking of
an "OLD TIME" unit more than 3o years ago
your gas is Freon R22...
The bad news is that is BANNED and your
choices are varied... interesting and all fairly
expensive.... (hideously expensive).
Sorry that is all I can relate on a MODEL 210.
(Lot of R22 scams going on out there... be careful).
((of course)).
30 pound canisters sell for under $800 US Dollars.
R22 FREON REFRIGERANT 15 oz CAN UNUSED eBay
May 14, 2017 | Whirlpool Refrigerators
I have a goodman Model CKL 36-1K . It says Factory Charge oz R22 . Does that mean it uses R22 freon? The guy who sold it to me says it uses 410a and was only 2 or 3 years old. The serial # is 040637071 ....
Hello, the unit is a 3 ton and was built in 2004. 0z R22 stands for R-22 refrigerant. Not sure why he told you 410a but if the unit says R-22 than that must be used.
Jul 06, 2012 | Goodman CKL36AR36 Air Conditioner
I have a Mitsubishi MS-XV07UV air con. unit - Have asked a local company for a price to check gas levels and re gas if required - as it uses R22 refrigerant he says it cannot be done is this correct ?
No. The pressure can be checked, regardless of the refrigerant type. But, if it needed to be recharged, the existing R22 Freon Gas would have to be evacuated and properly disposed of and the new, approved type R134a. would have to be installed.
Try contacting another service company and see if you get the same answer as the first.
Jun 14, 2011 | Heating & Cooling
Roof air not cooling, what is the correct freon to add r22?
On the outside of the unit on the cover,there is a nameplate rating that should tell you how much and what type of freon is in it.
Jun 29, 2010 | Coleman Mach 15 Air Conditioner
I need t recharge the freon. It takes R22. Where do I charge this system? I pulled the roof cap off and cannot find and caps to recharge the system
AC's routinely are sold/installed without charging valves.
So, unless your unit has been worked on/serviced in the past it will not have any place to charge with freon.
Note: unless you've developed a 'leak,' it is unlikely that you've lost any freon, and in the event that you have - it will take a Service Tech to install valves and charge your unit correctly.
I would call a Service Tech to assist.
hope this helps.
Jun 07, 2010 | Dometic Rooftop RV Air Conditioner
Who to added R22 freon to my a/c condenser unit and what hose on my gages need to be connected to hight pressure and lowe pressure
the red hose connects to smaller line...usually 3/8's....the blue connects to larger that has black insulation. The yellow to tank of freon. The unit must be running to put in blue hose. If unit nit running put in red hose. Must be done by someone with EPA 68 license
May 10, 2010 | Whirlwind FH-778 Air Conditioner
How do I replenish the Freon in my Sillouette model DWC283BLS?
you legally can't unless you are e.p.a. certified to purchase the type of freon in the unit and you have the equipment to do so,by law you need to evacuate the sealed system,then pressurize system with nitrogen and a small amount of r22freon,find the leak,recapture nitrogen/r22 and repair leak,then recharge unit with correct amount of correct refrigerant it needs,the equipment to do so is very expensive too
Nov 19, 2009 | Danby Silhouette DWC512BL Wine Cooler
How do you add coolant to a goldstar air conditioner
There are two lines leading into the unit, the high side aND THE LOW SIDE. tO ADD FREON you need to add a valve to the low side line. But if you have a leak that indicates that moisture is in the unit and you need to pull a valum to remove the moisture before ADDING ANY FREON. There are as last known three types of freon, R22, R134a and this last one I dont even know the name.
Sep 08, 2009 | Heating & Cooling
CAN R12 BE ADDED TO AN AC HOME UNIT USING R22.UNIT IS RUNNING BUT NOT COOLING
No, R12 and R22 are not compatible freons. You need to recharge with R22.
Jun 30, 2009 | Whirlwind FH-778 Air Conditioner
Heating & Cooling Logo
185 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
