Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The door goes up about 1 to 2ft and then stops. When it stops the overhead light on the opener and the led light on the wall mount switch goes off like the opener has lost power.
I has a strippes drive gear in my sears chain driven garage door opener. Replace the gear dirive and shaft with all the other gears provide by repair kit. On the first try the garage door opened ok but didn't open fully. I adusted the up pressure. now the door only moves a couple of inches up or down the the motor stops. Further adjustments made no change what should I do next?
Thanks
Jim
Posted on Jul 08, 2010
  • Don Maggard Jul 08, 2010
    Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
    President:
  • 3,197 Answers
It sounds like you have a loose connection either where the opener plugs in or on the logic board around the small transformer.
Posted on Jul 06, 2010
All of a sudden my garage door motor will not run, only clicks when pressing wall button or remote. garaage door moves manually.
Sounds like the trolley is stopped up against the stop bolt on the rail. This comes from bad limits. This happens often on older Chamberlain/Sears/Liftmaster etc openers.
Jul 16, 2010 | General Electric GE 13-438 Overhead Garage...
Garage door opens w/ Power outages
You will need to get a surge protector on this unit first of all. You will have to replace the logic board and maybe the wall button or sensors depending on how bad the surge was. Any time the power goes out the logic board can be affected by it. Thanks BB
Oct 06, 2009 | General Electric GE 13-438 Overhead Garage...
I have to hold down the wall mounted opener the entire time that the door is closing. The remote will not close the door. They both open the door fine.
Look at the back of the opener, the LED light blinks. Count how many blinks, then go to the troubleshooting guide to find the fault.
Jun 28, 2009 | liftmaster Chamberlain Garage Door Opener...
Door goes up, Won't go down.
It sounds like the limits are out of adjustment. With the door down, rotate the down limit until it clicks. Then raise the door manually, and set the up limit until it clicks. You should be able to hear the switch 'click' when it activates. Pay attention to which way the plastic nuts are moving on the screw going up and down. That way you know which way to turn them to set it.
I have a sears craftmen garage door and the control switch on the wall light keeps flashing and I need to know how to get it toa solid light and when I press the button to close the door it goes few...
When the door reverses to the open position and the main light flashes 10 times it is a door sensor problem. Usually the sensors get bumped and need to be tweaked so that they are once again pointed at one another. Each sensor has a small light that must be on for them to work. The light on one sensor stays lit all the time and the other sensor light is only on when they are pointed at one another.
The flashing light in your wall control is a separate problem. One of the buttons on the wall control has an icon of a lock. Press and hold it for 3 seconds and release. It should stop flashing.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't open
Unfortunately storms do bad things so door openers sometimes. It has most likely gotten to your logic board. You can remove that board and look for burnt or missing traces of the print. Random flashing of that LED is normal.
May 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Must hold wall unit to close garage door...
there is an error in the system. most likely The safety beams (mounted on the track near the floor) are out of alignment and the LED light should be blinking. The garage door opener will not let the door close if the beams are misaligned. Realign them and the LEDs on the beam or on the operator will stay on. you should be able close the door now with one push.
Apr 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Green light is flashing on my garage door opener on the inside of my house/craftsman opener
Hi. The green light was flashing and ny transmitter in the car would no longer operate the door. On the back of the liftmaster, just below wker the small wires go in, there is a small, flat, green button. I pressed that with a stick and it solved the problem.
Jun 27, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
234 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
