Question about Logitech QuickCam Pro 5000 Webcam
The istall declare : do'nt install because win install is corrupt , bat oll program ( and win) ran in regular mode, with yours adjornmments
  • 1,557 Answers
Download a free registry cleaner from the internet tucows.com has some that might fix your corruption problem
Posted on Jul 06, 2010
How can i speed up a emachines computer running windows 7?
i did some work on a new computer that was running extremely slow. I did a control alt delete to go to win task manager. then go to processes and saw that one program was consumin a great amout of the processor usage. I disabled the program and the machine ran fine, I don't know what the program was, but appearently it was not needed. If you get into windows either in regular mode or safe mode, see what is running on your startup menus. something is tying up the computer. i have not used either of your pieces of soft ware, but maybe the Avast is set to do a scan everytime the computer boots. Hope this helps.
Jul 11, 2014 | Computers & Internet
Could not find the main class: Program will exit
Are you trying to access a program that you downloaded?
Are you trying to program something?
This is an error that is encountered when a program is started but the system cannot find the main class (The first step to starting the program which controls the whole flow of the program)
If it is something you downloaded from a rookie developer, or something you programmed yourself take a look at your main function, it is probably declared improperly. Google the specific language you are using to see how it is supposed to be declared.
If it is a mainstream something you are trying to install and run something somewhere corrupted. Try to re-download and reinstall. If that doesn't work it is possible something in your registry is corrupted... unlikely, but possible.
Feb 16, 2014 | Computers & Internet
Win 98 in dos mode i get this message " no cd rom or msdex.exe is not loaded " when trying to acces game disk in cd rom
1) Does it say MSDEX.EXE or MSCDEX.EXE?
2) Have you ever used that CD successfully on that computer before? (DVD's don't work well in MS-DOS).
3) Verify its trying to run from the correct drive. D:, E:, etc...
That aside, I'd recommend a glance at the following support page. It sounds like your driver isn't supported or your game is referring to a specific drive that doesn't exist.
MSCDEX Help
(make a back-up copy your autoexec.bat, and rename it autoexec.bat.orig just in case)
Get an older compatible driver for your CD-Rom that is windows 98 compatible, so something around the year 2000 is probably ideal.
Uninstall your current driver and reboot. Scan for Hardware changes and install the new drivers for your CD-ROM. Then check your config.sys and verify the driver. If its not correct, open the autoexec.bat in an editor. in the portion of the autoexec.bat that has MSCDEX..exe program you'll put in the following. (replace DRIVERNAME with the driver name, typically MSCD001)
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:DRIVERNAME
Save, reboot. Let me know how it goes!
Feb 08, 2013 | Computers & Internet
When i turn on computer the dell logo comes uo and then it says its missin win32
Win 32 is the generic name for all 32 bit Windows platforms and includes Windowes 95, Windows 98, Windows Me, Windows NT, Windows 2000, Windows 2003 Server, Windows XP and Vista.
This is one of the Major program enable for your Windows to function.
So it would be best to perform a reinstall of OS
Sep 17, 2010 | Dell Dimension 4100 (-JM0TB01) PC Desktop
I have chnged my computer system form XP to Window, now I cannot install PrintMaster Platinum Version 17? Is there any way that I can istall this program disc?
Thank you for your question.
In this instance it is easier to direct you to a video on the "Microsoft" website regarding installing older programmes. This is much clearer than trying to explain in writing.
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
All the best with your install.
Kind regards
Jul 20, 2010 | Broderbund PrintMaster Platinum Version 18
NTLDR MSSING, how can i solve this?
NTLDR is short for NT loader – a program loaded from the hard drive boot sector that displays the Microsoft Windows NT startup menu and helps Microsoft Windows NT load. So when it goes missing for some reason, your windows cannot load.
Cause:
1. Computer is booting from a non-bootable source.
2. Computer hard disk drive is not properly setup in BIOS.
3. Corrupt NTLDR and/or NTDETECT.COM file.
4. Misconfiguration with the boot.ini file.
5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
6. New hard disk drive being added.
7. Corrupt boot sector / master boot record.
8. Seriously corrupted version of Windows 2000 or Windows XP.
9. Loose or Faulty IDE/EIDE hard disk drive cable.
if there is attached drive ,remove the drive first before restarting the system if not then if you had access to another computer, copy the NTLDR and NTDETECT.COM which is available from the recovery CD which comes with computer. If you do not have the recovery CD, its available on microsoft site or is available from another computer using the same Operating System (Windows XP ). The location may be C:\i386\ntldr C:\i386\ntdetect.com use a bootable disc to restart the computer (the Win XP bootable CD or Win 98 bootable CD worked). After entering MS DOS mode, copy these 2 files to the C drive in the proper location. After restart, then pressing F10 on start up (used for system recovery ), then start the repair of Windows via system recovery This will reinstalled all Windows drivers and system files, while preserving all data on your computer.
Sep 16, 2009 | Computers & Internet
I download Audio drive for HP compaq nx9010 but if i try to install it away tell me that istallation fail
uninstall your old driver and then remove all the file exist connected to the sound driver file on program files,,if there is a trace, it probably reject all new driver instalation
Jun 20, 2009 | Computers & Internet
IBM ThinkPad 600E trying to put os on it
that is correct.. IF you are using windows 2000 the files are NOT the same as the files under XP.. Your best bet is to EITHER install the complete XP or find the win2k installation disk,, even an upgrasde disk for win 200 can be found probably around 100.00. IF the system isn't booting from your XP disk IS Your disk an ORIGINAL or a copy of the original?.. If for example your CD rom is drive E then see if you can find a win XP emergency boot disk and access the CDROM goto e:\windows\i386 then run the setup program, many cases this will overwrite your existing OS.. but do so at your OWN RISK I will not be accountable if you lose any of your important files.. some win98 emergency boot disks can access the cdrom but you may have to make certain additions to the autoexec.bat and/or config.sys files. be careful when using DOS because you can completely delete EVERYTHING on the HDD if you use the right command(s). As A DOS BABY I have performed many lazarus miracles but I have been using dos since the early 70's
May 22, 2009 | Computers & Internet
Pc945gz7mc-k52h
Put your hard disk to another computer format all drives unallocate the drives and aloocate in newly again..then istall the OS newly then put back in your system and check whether it works...
Sep 26, 2008 | Computers & Internet
Logitech QuickCam Pro 5000 Webcam Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
