Question about Lasko High Velocity Space-Saving Blower Fan HVB - 4924
My fan only works on the high setting. how do i
The fan's lower power settings stopped working one at a time. only the high power setting works now. how do i fix it?
  • 24 Answers
The control panel contactors have more than likely burnt
Posted on Jul 06, 2010
Have a 2009 Nissan Quest I can't turn the heat off. Just stays on a high level of blowing out heat .
If you have a fan that has different speed settings (1234, or low med high etc) and the only one that works is high - then the blower resistor pack has failed. If you have a climate control unit (where you just pick a temp you want) then the fan is controlled by the heating system and it sets fan speed. If you have climate control style try lowering the temp to a lower setting (current temp in vehicle) and see if fan slows down. If not then climate control unit or fan resistor bad. If dial type and you get nothing on lower settings (only high works like mentioned above) you need to change blower resistor. It is located under dash near the fan itself. Look for small unit bolted in duct near fan with wire plug going to it.
Feb 23, 2015 | Nissan Cars & Trucks
Heater fan only works on high
Replace the step switch, the contacts are burned out or just use it on high until that speed doesn't work...your choice..
Dec 31, 2012 | 2000 Buick Century
97 Jeep Grand Cherokee fan switch works part time.
Probably the switch. Could be the blower resistor.
On most models the high position bypasses the resistor which cuts down voltage for lower speeds.
Jul 06, 2012 | Jeep Grand Cherokee Cars & Trucks
A/c& heater control fan only works on #4 setting
If the blower motor only works on high speed then the blower motor resistor has burnt out on the lower settings, and will only send power on the high setting because it is straight battery power.
Jul 20, 2011 | 2004 Hyundai Elantra
When the mode button is pushed, I only receive the option of dehumidifying, or just fan. The manual claims it has a heat option but it is not available. A friend of mine has the same one and they have the...
Sorry to read about your problem, I hope this helps you out.
Their has to be a model difference issue . I have checked the Manuel and have put a copy of the section, for modes. and their is no heat only mode.
Your unit uses heat anyway, so i really do not know how, heat only would help you. I would say to look at the sticker on your friends model, and see if the numbers are exact.
Default Setting:
When the unit is first connected to a power supply, the electronic circuit board will automatically default to the following factory settings;
Mode: Dehumidifier Humidity Set Air Value:60% RH Fan Speed: = Low
NOTE: In the event of a power failure or the unit is switched 'Off', the most recent settings are retained and restored once the power is switched "On"/resumed.
IMPORTANT NOTE: Depending on the ambient humidity conditions, when power is restored or switched 'On' the dehumidifier may not start automatically under the factory or custom (see page 7) default setting. This is an indica- tion that the ambient RH% level of the surrounding envi- ronment is lower than the current default setting and it may be necessary to select a lower set RH% value.
DRY MODE SELECTION: 1. The unit does not have to be switched on (opera- tional) to select/set a program. All programs can be selected with the unit in the "off" position.
2. Press the MODE button until the Dry symbol is shown in the mode area of the display. Note: Each time the MODE button is pressed, the setting will alternate between DRY (dehumidifier) and FAN (only) mode.
3. Press the or cursor buttons to select the desired RH% operating value. To select CONTINUOUS operation,pressthe buttonuntilthesymbol"--" appears in the SET AIR display. During CONTINUOUS mode operation, the humidistat (control) will be by-passed and the compressor will operate non-stop regardless of humidity conditions.
FAN SPEED SELECTION:
4. Press the fan symbol on the keypad. Each time the button is pressed, the mode selection will alternate between "High Fan" and "Low Fan" speed options. The fan speed you select will appear in the LED display; either a 4 blade fan symbol for 'high fan' or a 3 blade fan symbol for 'low fan' will be shown in the display area.
5. When all settings are complete, press the I/O button to start the selected operation (MODE) and the blue opera- tion light will illuminate.
FAN ONLY MODE SELECTION:
1. Press the MODE button until the fan blade symbol is shown in the mode area of the display. 2. Press the "Fan" symbol on the keypad. Each time the button is pressed, the mode selection will alternate between "High Fan" and "Low Fan" speed options.
3. When all settings are complete, press the on/off button to start fan mode operation and the blue operation light will illuminate.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Danby DDR586R Dehumidifier
The heater in my 2002 Dakota works only at the very highest setting. There is no power at the lowers settings. The defrost light doesn't come on until that setting also, so definantly no power. When turned...
I'm assuming you mean the fan only works on high. If that's the case the blower motor resistor is bad. When the fan switch is on high it puts a full 12Volts to the blower motor. When you have the switch in any other possition, the voltage is routed through the resistor and reduced thus making the motor run slower.
Dec 14, 2009 | Dodge Dakota Cars & Trucks
My fan/blower won't run on high setting. It works
Replace relay under blower motor, under hood.
Jun 25, 2009 | 1993 Buick LeSabre
2005 jeep grand cherokee 4.7 Ac fan lost the 3 lower settings, only the high setting still worked. For a while the lower fan settings would just come on, and then go out again. The high fan setting...
Well, the blower resistor handles the lower speeds and the hi-blower relay handles the hi speed only. if the fan still works on the lower speeds then the resistor is bad. if the fan doesn't work at all then your motor has failed and or burn't the relay out also. if you can get your blower to start by hitting the kick panel above the pass. side foot area then the motor is bad. if you are handy enough to drop the kick panel and access the motor then check the connections at the motor. Then wack the motor and see if it comes on then. you will most likely find the problem if you follow those simple rules above. Good luck.
Jul 31, 2008 | 2001 Jeep Grand Cherokee
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Lasko High Velocity Space-Saving Blower Fan HVB - 4924 Logo
241 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
