Broken screen MT 3421 - Computers & Internet
  • 150 Answers
You have a serious problem. Replacement screens tend to be ridiculously expensive, I was once quoted $850 for a Sony Vaio, not including labor. Also the replacement procedure is quite involved, if you don't have a background in handling delicate electronics, both in terms of mechanical issues and also the real danger of damage by static electricity.
Sometimes you can get lucky and find a replacement screen on Ebay. There is no way to fix the screen, except replacing it.
Another half-way solution is to hook up a cheap external monitor or a compatible TV to your laptop, and use it as a desktop.
Posted on Apr 18, 2008
Need Lcx 15 mt update 3.6.0
You might find what your looking for here.
Jun 13, 2014 | Lowrance Boating
CABLE repair
I would suggest sending it back for repair, if you make a mistake you can damage your car as well as your OBD II reader.
Jan 20, 2014 | NRS OTC 3421-88 Genisys OBD II Smart Cable
Mt-03 misfire high revs
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system, carburetor and/or filter.
12. Old dead or bad fuel.
13. Fuel tank vent system plugged or carburetor vent line closed off.
14. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
15. Carburetor controls misadjusted.
16. Damaged carburetor.
17. Incorrect valve timing.
18. Weak or broken valve springs.
19. Damaged intake or exhaust valve.
20. Check for engine trouble codes
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Yamaha MT Owners Club
Total Motorcycle Forums
Yamaha MT 03 Service Manual
OEM parts for Yamaha
YAMAHA MT 03 Owner Manual
Feb 17, 2013 | 2007 Yamaha MT-03
This monitor gives me a complete blank white screen when plugged in even after checking with multiple computers what part would need fixing or replacing for it to function properly?
check first any broken ribbon wire going to lcd panel or broken screen display. if those are good, the cause of white screen would be bad lcd controller board.
Dec 28, 2012 | Computers & Internet
How to clear error code c 3421 on konica bizhub c353
While holding down the utility/counter button and turning on the machine go to screen that say trouble reset press it says OK that power off and turn on again if comes back need a fusing unit.
Mar 13, 2012 | Konica Minolta Konica Bizhub C353 Drum...
How to clear error code c 3421 on konica bizhub c253
C-3421 = Fusing heaters trouble
To Reset:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
May 19, 2010 | Konica Minolta bizhub C250 All-In-One...
I he a eclipse cd 3421 how do i unlock it
call an eclipse dealer. they will unlock i think the charge is $35
Feb 06, 2010 | Eclipse CD3422 CD Player
Need replace bsaket in PegPerego Duatte MT or call 1-800-671-1701 order it from the manufacturer direct.
Good Luck! from Moms Just Know
Sep 14, 2008 | Peg Perego Duette MT Newport Twin Stroller
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
