Question about Cycling
How do i adjust the height of my handle bars on my trek 2.3 road bike
    Brigadier General:
  • 8,546 Answers
Modern threadless headsets require height choices to be made at build time because once cut, the steere can not be made longer. Many bikes come with a medium height stem and a few spacers underneath it to allow for lowering it. All threadless stems can be flipped over to change tthe rise angle and you may find a solution in that. Or you could gog to a Local Bike Shop and have them advise you on replacement stems with diffrent rises and reaches. The extra spacers, if any, can be placed above the stem untill you're satisfied with the fit. Then you can cut the excess off and save the spacers or leave it as is, but it looks dorky..
Unless you understand threadless stems, you should not attempt to change anything as your life depends on correct tightness. Look here:
http://parktool.com/repair/byregion.asp?catid=72
Posted on Jul 06, 2010
Trayl bike owners manual. or how do I adjust the height of the handle bars?
Your bike has a modern "threadless headset" which usually allows very little vertical adjustment. See this page for an explanation of how to change height on that style:
How to adjust handlebar height BikeRadar
If you can't adjust enough that way you can try buying a shorter stem or one with a steeper angle,. The final option is to buy a "stem riser" - Google the term for more info - needs to have correct dimensions for your bike
It's best to get advice at a bike shop as to what option is best for you..
Jun 04, 2017 | TRAYL Cycling
How can you raise the handlebar height?
Robert, Below I have posted links showing how to adjust handle bar height for most, some bikes bars are not adjustable and are welded. If the links do not help I suggest you do a google search. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Raise Bicycle Handlebars
How to Adjust Your Bike Handlebar Height
How to Adjust Handlebars
Tech Talk How to Raise your Handlebars
Aug 20, 2016 | Cycling
Adjust handle bar height ?
looking at some pictures of this model, most appear to be using an "Aheadset" style handlebar stem, there is not any way to raise this type of stem. Your alternative is to go online or to a local bike shop and purchase a new stem that will fit your fork and handlebar that has a higher pitch angle to it, or a compatible adjustable stem that pivots. Expect to pay $25-$50 or more for a new handlebar stem, not including labor to install.
Apr 06, 2016 | Marin Belvedere Commuter Road Bike
Handle bars need to be adjusted up in height
You need to loosen the neck of the handle bars with a anlenwrinch.After that you will be able to adjust the hieght of the handle bars by lifting the top of them.
May 30, 2010 | Disney Cars 16-Inch Boys BMX Bike
Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
Apr 03, 2010 | Mongoose Exile 26 Men's Full-Suspension...
How do you adjust the height of the handle bars?
What kind of stem are we talking about. Modern stems are not adjustable other than to add or remove spacers under them or flip the whole thing over for a drastic change. Once cut to length the stem adjustment is very limited as you can't really get away with adding spacers for additional height. Beyond its current physical limitations you would probably need a different stem.
Here's a great resource that explains old-school and newer stems.
Mar 19, 2010 | Fuji Road Bike Saddle/embroidery/chromoly...
Need to adjust height of handlebar on a jeep sahara bicycle
Most bikes use an allen key to adjust the height of the handle bars. Typically 6mm. But be careful most bikes do not have much adjustment that can be done to the height of the handle bars. The handle bar stem will have a line on it of the "minimum insertion". That line must be below the top of the head set nut for safety reasons. Look for the line as you adjust the height.
Oct 03, 2009 | Jeep Cycling
Cycling Logo
105 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
