Question about Dell Latitude D600 Notebook
Battery My lap top will not turn on with battery in and my power cord is blinking
    Genius:
  • 3,587 Answers
Ok..remove battery from laptop..plug in ac adaptor, then see if it runs..
Posted on Apr 18, 2008
My lap top its not responding to power button and i cant start my lap top
Unplug the battery and the power cord. Hold down the power button for 30 seconds. Plug back in the battery and power cord. Try powering on the laptop. If it powers on you are good to go. If not try contacting Lenovo support.
May 31, 2014 | Lenovo 3000 G530 Notebook
HP Lap top touch pad locked. How to correct please
By now you probably figured out you have to remove the power cord and battery to turn off the laptop. Let it cool down, 30 minutes or so, and then replace the battery and restart the laptop.
Feb 17, 2014 | Computers & Internet
Lap top wont start
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 19, 2012 | HP Computers & Internet
My lap top turns on and then turns off
What model is your laptop? What Operating System?
Remove the Power Cord, Remove the Battery, Remove the screw from the cover that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 26, 2012 | Dell Computers & Internet
Lap top will not turn on. receives power from the cord and power supply, but has no indicating lights on the lower left part of laptop. was able to get the lap top to operate after removing and...
Measure the voltage at the terminals of the battery in the laptop. If there is no supply then the power section in the lap tops main board is faulty and needs a check.
However if there is voltage then the battery must be checked if this has failed to charge and is defective. check if the cord from the adapter is not short as it will result in DC power cut off.
Mar 24, 2011 | HP Computers & Internet
My lap top was droped by a teacher. it just blinks power button
Ouch! Try removing the battery, and reinstalling it, also take out hard drive and do the same. also do the memory the same way. Might have knocked them loose on the drop. Good Luck.
Feb 05, 2009 | Dell Latitude D600 Notebook
My lap top just swiched it self off and now just seems as if its dead, when i plug the power cord in nothin happens either, anything i can do?
Try this (works sometimes):
Remove the power cord and the battery. Press the power button for a few seconds. Replug the power cord and power up the laptop. If it works, turn it off, and insert the battery again.
Oct 25, 2008 | Computers & Internet
Lap top not turning on
Try removing the battery, waiting 30 seconds, then plugging it back in. Plug in power cord and try to turn it on.
Feb 02, 2008 | HP Compaq Evo n610c Notebook
Dell Latitude D600 Notebook Logo
50 people viewed this question
Alun Cox
