Question about Mitsubishi WD-52525 52" Rear Projection HDTV
How to reset lamp timer without remote - Mitsubishi WD-52525 52" Rear Projection HDTV
  • 58 Answers
You cant, when you remove and replace the lamp cover the tv will come on and ask if you changed the lamp. you need to press enter on the remote (not the tv) to reset the counter. go buy a universal remote and program it to your tv then use that. make sure the remote you buy has an enter button. most should, but you never know.
Posted on Jul 06, 2010
  • a b Jul 06, 2010
    Not helpful?
2 Suggested Answers
  • 668 Answers
SOURCE: reset timer toshiba 62hm116
I do not think failing to reset the Lamp Timer would cause the Lamp not to light. You need to get into the Factory Menu while the picture is on in order reset the Timer. I believe you have a Ballast issue either because the Power Supply is not powering the Ballast or the Ballast not Powering the Lamp. In either case, the only way to know is to have a professional to check it out and give a estimate for repair.
I hope this helps,
Skyassoc
Posted on Aug 29, 2009
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
How reset lamp timer without remote
You will have to navigate the menu from the projector using the up buttons.
Aug 16, 2014 | PLUS Vision Corp. Office Equipment &...
Can I reset the lamp timer without the original remote
No, original remote is needed for this--a universal will not cut it.
If Panasonic the remotes are usually reasonably priced and have all the features you really need.
Mar 26, 2012 | Panasonic PT-50DL54 50" Rear Projection...
HOW DO I RESET THE LAMP TIMER ON A SONY KDF55WF655
Procedure for resetting your lamp timer,
Use the Remote Commander to put the set into service mode to display the service menus.
1. TV must be in standby mode (Power off).
2. Press the following buttons on the Remote commander within a second of each other: DISPLAY ==> Channel 5 ==> Volume + ==> POWER. The first service menu (TV) displays.
To reset the Lamp Timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Jun 30, 2011 | Sony Televison & Video
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    How do I reset the Lamp timer o an NEC MT1050 projector... Without the hand held remote control?
    On some Projectors that I used to service, Holding the power button whilst plugging into power did a lamp timer reset. ( Of course check the lamp is fully seated and the lamp door is closed
    Feb 24, 2011 | NEC MT850, MT1050, MT1055, MT1056...
    Replacing the projection lamp
    Try resseting the lamp timer following the info below: Procedure for resetting the KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655 or KDF60XS955 lamp timer:
    Dec 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
    Projection lamp timer reset
    I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
    Jul 19, 2008 | Panasonic PT-44LCX65 Television
    Removing the "lamp needs replacing" warning message
    Hi guys
    Firstly you need the remote to reset the lamp timer.
    Hold down the left and right scroll buttons on the remote and press menu. That will reset your lamp timer.
    Jul 31, 2007 | Sony VPL-EX1 Multimedia Projector
    Mitsubishi WD-52525 52" Rear Projection HDTV Logo
    719 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
