Question about HP Photosmart C6180 All-In-One InkJet Printer
Paper tray empty error message
For some reason my printer has stopped printing. It gives me an error message saying that the paper tray is empty. I've checked for jams and even tried different paper weights to no avail. I hear it trying to pull in a piece of paper and then it gives the error message. I looked with a flashlight and see that there is a little "foot" thing that must drag the paper forward to the rollers but it does not move. Is it supposed to? Could that be the issue? The error message says there is no paper. I have tried different levels of paper but to no avail. It has ceased to print. Help!
    Genius:
  • 3,422 Answers
Please CLICK HERE
Just follow the steps given and your problem will be solved.
Goodluck,
Please don't forget to rate the solution
Posted on Apr 18, 2008
  • Priya darshan Apr 18, 2008
    Please don't forget to rate the solution as fixya!!
    Genius:
  • 3,587 Answers
No worries...it could be your drivers are shot..turn off machine, and let it sit for 10 minutes..unplug from computer, turn on, then tray a test page from front panel
2 Suggested Answers
khanmohammad
  • 188 Answers
SOURCE: Paper tray empty error message
Please click on the web link given below and perform the steps as provided in the web page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=us&lc=en&dlc=en&product=1153494
This should fix the issue.
Have a great day!
Posted on Mar 26, 2008
Bypass tray has correct paper size but gives error message to add correct paper size. Won't print
Once you have the message, try removing the paper from the bypass tray, then introducing it again. Alternatively, leave the tray empty then send the data, when it asks for paper, introduce your 11 x 7, and it should work.
Mar 19, 2014 | Konica Minolta Di3510 Copier
Lexmark T640 printer will not print- get message- media tray empty
Check if the paper tray has enough amount of paper in it. If it has, check if the paper guides are correctly placed and is set to the correct media size.
Aug 02, 2012 | Lexmark T640 Laser Printer
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Jul 03, 2008 | Lexmark T640 Laser Printer
Paper empty message when pdf
Could be a page size problem.
A4 paper in the paper tray, but what page size does the PDF think it is?
Dec 30, 2007 | Samsung CLP-510 Laser Printer
Have a great day!
Nov 23, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
172 people viewed this question
Seeker5211
Seeker5211
