Question about Samsung SyncMaster 244T 24" LCD Monitor
The monitor power button in the front was blinking green for days and now the monitor doesn't seem to even power up. I'm not sure what happened but it seems dead. Any ideas for troubleshooting?
  • Samsung Master
  • 11,800 Answers
The power source of the monitor has died. The monitor must be opened and the source fixed by an electronics repairman.
Posted on Jul 06, 2010
Dell poweredge t110 server Amber error light on front panel blink one time
Had the same thing happen to me today and in my case it was a code 18 as they come...
It started while I was installing a video card adapter for a dual monitor setup. The solution - I had to simply close the side panel I had left open for testing and then reboot the server. The intrusion alarm went off.
Feb 02, 2012 | Dell PowerEdge T110 Server (GB/2GB)...
After a storm the other night my Proview PL866s amber light is blinking - however when I press the amber button (which usually turns green and then it works) nothing is happening except blank screen and...
If this happened after a storm, the monitor may have been subjected to a power surge, which unfortunately might have killed it.
If you have another monitor (or a friend who has one) try plugging that other monitor into your computer. If the second monitor works, yours will need to be replaced as the input was probably destroyed by the power surge.
If the second monitor also doesn't work, there may be a problem with your computer, most likely with the power supply (this is the part most often damaged by a power surge). You may want to have it examined by a professional computer repair person at that point.
Hope this is helpful!
May 16, 2011 | Proview PL866B 18 in. Flat Panel LCD...
I have a lcd monitor problem, it wont turn on. the little light thats suppose to light up when you plug the monitor doesnt light up.. when i press the power button the green light appears for a sec and the...
sounds like a power issue with the monitor. try to remove and reconnect its power cord. If same thing happens, try using a confirmed working power cord like the one you use with the computer and make sure you test it out using a confirmed working power outket. If it has the same issue, would mean you need to get a replacement monitor. Refer to the vendor if it is still in warranty.
Aug 31, 2010 | Computers & Internet
My desktop monitor will blinks yellow and green, no picture
Do you have another monitor you can try. Sometimes they do go bad.
But that would be the first thing I check, make sure it's the monitor.
Sep 12, 2009 | HP Compaq FS7600 17" CRT Monitor
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
Feb 10, 2009 | Soyo DYLM1986 Monitor
DONTKNOW WHAT TO DO
Your monitor need repair. Sounds like a power supply problem. The power supply is shutting down due to an overload.
Lou
Aug 29, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
17" veiwsonic power blinking green
The flashing green power button is a well known electronic problem with this (and other) Viewsonic LCD monitors. There is a YouTube video (do a search) showing how to disassemble the VX924 and find out whether the problem is related to blown capacitors. When I took my VX922 apart I discovered 6 bad capacitors out of a total of 7 on the power supply circuit board.Only recommended for those handy with a soldering iron.
Jul 28, 2007 | ViewSonic VX922 19" Monitor Flat Panel
Samsung SyncMaster 244T 24" LCD Monitor Logo
709 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
