Question about Refrigerators
Odel 253.67872504 refrigerator has cold top mount freezer section but warm refrigerator section despite different temperature settings.
  • 958 Answers
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
Posted on Jun 25, 2008
SOURCE: MZD 2766GE refrigerator: freezer side is cold but refrigerator side gradually warms after a week and then freezer side warms.
fan won't start by itself.
Posted on Aug 10, 2008
  • 400 Answers
SOURCE: Whirlpool Top-Mount Refrigerator Freezer warm, cracking noise
8yr old? Buy a new one. The cracking sound is from expansion and contraction of the cabinet and ice cooling or defrosting. It can be as simple as a bit of a top up of refrigerant, but can also be that your compressor has worn down the valve plates and therefore is not producing sufficient pressure throught the system.
Posted on Mar 06, 2009
SOURCE: Kenmore refrigerator model 253 not getting cold
i have the same problem: botttom of refrigerator does not cool.
freezer working ok.
Posted on Mar 18, 2009
Maytag317
  • 1136 Answers
SOURCE: I have a Kenmore refrigerator (model 253.63732300)
Hi, Check in the freezer section and see if there is frost building up on the rear panel. Notice if the evaporator fan motor is running. If there is frost, you need to repair the defrost cycle.
Please let me know if this what you find so I can assist you further.
Vic
Posted on Jun 14, 2009
What could cause the fresh food section of my refrigerator to be too warm?
UR COLD CONTROL THERMOSTAT, UR AIR FLOW VENT, UR THERMISTORS, A EVAPORATOR FAN NOT WORKING OR OBSTRUCTED
Feb 24, 2015 | Refrigerators
The bottom of my refrigerator remains warm despite turning the knob to MAX.
If it's frost free check that the fan is running in the freezer section.
If ice is causing it to stop then it your defrost control that is causing the problem
Jan 09, 2014 | LG LRTBC1825T Top Freezer Refrigerator
I have a Matag Refrigerator Model MTB2156DEW. The freezer is located on the top of the fresh food compartment. For approximately a week the refrigerator has been constantly running without cycling. ...
Defrost the unit. The fridge section cannot cool if the freezer is iced over since the fridge gets its cold from the freezer. If you don't have a second fridge use a hair dryer to speed the defrost.
Apr 06, 2011 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
My GE TFX30PP is constantly running and doesn't turn off. The freezer is very cold but the frig side isn't cold enough. A repair guy put in a new "cold contol" sensor but it didn't help.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
I would also clesan the condenser coils off.
Add a comment
Dec 24, 2010 | GE Profile Performance 29.8 cu. ft....
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Fridge side cant keep 100 percent cold
Have you noticed a big difference lately in the cooling of the cold food section? Any time you open doors to a refrigerator or freezer you allow them to exchange room temperatures with inside ambient temperatures. The only time you should be concerned is when these temperatures begin to remain abnormally high. Many times the temperature rises in the kitchen while diner is prepared. Those temperatures also affect how long your refrigerator need to run to maintain the temperature settings you select. Your refrigerator has something called an Adaptive Defrost Control. If you should have problems with it you would notice a big difference.Another thing that can help is to make sure the condenser coils below refrigerator remain clean and clear of dust. The warm air circulating below your refrigerator is as important as the cold air inside. As for the vents that lead from freezer to cold food section they sometime become obstructed especially if they have a damper inside and frost locks the damper shut. If I missed something here please let me know, Thank You, Sea Breeze
May 23, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Side-by-side fridge is freezing food on bottom shelf
Look to the freezer section for a possible frosting on the back wall. If you have a defrost problem in the freezer and air circulation stops cold air from the freezer may settle through the return area of the duct between the refrigerator and freezer section because cold air is heavier the warm air. Normal circulation follows a clockwise pattern.
Also your setting of the refrigerator temperature may be set to cold. Once again cold air settles to the bottom.
Jun 02, 2008 | Whirlpool Refrigerators
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
